2004 1500 5.7 Steering rack problems - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - News Desk > Newbie Checkin!
Newbie Checkin! New to the forums? Introduce yourself here!
Old 08-13-2010, 08:51 PM
HOLMES188 HOLMES188 is offline
HOLMES188 is on a distinguished road
Post 2004 1500 5.7 Steering rack problems
I purchased this ttruck about 3 years ago, it has a 6" lift on it. I bought it with 70,000 miles on it, I now have 103,000 miles on it. Back in January of this year I developed a power steering leak on my steering rack up by the pinon gear. So I replaced my steering rack, I did use a napa refurbished rack, still cost me $200. It seemed to work great for about 3,000 miles. Then it just randomly blew a tie rod seal on the passenger side, lost all my power steering fluid in a matter of seconds. I was able to get napa to warranty the rack, and I replaced it again. This was in May, now another 3,000 miles later it has blown the seals on bolth sides, the tie rod boots look like baloons. Once again napa will warranty the rack for me but I believe I am just fixing the problem not the cause. Now I am questioning is it my 6" lift putting the tie rods at and angle causing this to happen? I was told maybe the internal pressure regulator on the power steering pump is not working, allowing to much pressure and that I should replace the pump. Before I spend $230 on a pump, I want to make sure I am not just throwing parts at this. Anyone have any ideas? I almost wish I had left the original one on. I assume that was the original one from the factory. I hadnt seen any signs that it had been replaced before. So anyone know what may be going on?? I would greatly appriciate any help
Old 08-13-2010, 09:02 PM
Welcome to the forum.
Sure, the pump might be the culprit. Or, the 6" lift is stressing the rack and you might wanna go with a new, beefier one (not cheap by any means) from a 3/4ton if it will fit. But that's just a guess on my part.
Maybe our Dodge Tech here will have some better help for ya.
Good luck!
Old 08-13-2010, 10:23 PM
Rep:1625
Welcome to the forum!
Old 08-13-2010, 11:57 PM
Rep:4264
Hello and welcome to the forum, glad you joined us here! Sorry to hear about your problem and while I don't have any advice for you, like Michael said, hopefully our resident tech will be able to chime in on this for you, but good luck with that and be sure to keep us posted! Lots of great people and info here, so feel free to look around and join the conversation and I hope you enjoy the site!
Old 08-14-2010, 12:09 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Welcome to the site! Hope you enjoy it here!
Old 08-14-2010, 01:31 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Does the differential point up or straight back?
Reason I ask is differential position is great indicator of whether the 6" lift was done correctly. If it is straight back aka stock, the lift is more than likely the cause of your problems.
When you do a lift like that, everything has to be adjusted accordingly.
Brian:
Old 08-14-2010, 09:12 AM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
Hello and welcome!
We are glad to have you, I hope you enjoy the board and get your problem solved!
Old 08-14-2010, 11:19 AM
mattg1500's Avatar
mattg1500 mattg1500 is offline
Vehicle: 2005 Dodge Ram QC
Rep:22
mattg1500 is on a distinguished road
Ther was a TSB for the power steering line on that truck, I had mine replace by the dealer, because it kept leaking. Also Im not sure what lift kit you have but ones I have seen do not re locate the rack I know mine doesnt
Old 08-14-2010, 11:48 PM
Glad you joined us and welcome to the Z for Rams from Baltimore . You should beable to test the pump output . Also did you flush the system real good before replacing the rack ? You may have some debris suspended in the fluid . I'm not sure if they make a in-line filter for the return line or not . If you could go to the top of the page to the User Cp and complete your profile that would be great . Helps us see what you have when your posting a question or comment . Do you have any pictures of your truck ? Have you done any mods or have plans for any ? Any of your friends have Rams ? Tell them about us . We would love to have them . You will find this site is full of a lot of talented people . So if theres any question that you need answered , just shoot away . Talk to ya soon . Tom
Old 08-16-2010, 02:39 PM
iRESQu iRESQu is offline
Rep:2217
Hello and welcome aboard the ForumZ. Sorry I am a little late getting to welcoming you!
