Old 08-14-2010, 10:35 AM
MoparMadness08's Avatar
MoparMadness08 MoparMadness08 is offline
Vehicle: 2008 Dodge Ram
Color: Cool Vanilla
Rep:63
MoparMadness08 will become famous soon enough
Default 180 stat throws on check engine light?
Has anyone installed the 180 stat and have the check engine light come on. i havent installed mine yet but heard it might throw the CEL on.
DSP 91 Oct Tune, BFI Intake, 14" Magnaflow, 180 Stat, Lund Genesis Tonneau cover, Recon LED light bar, Rocky Mtn ATS 305/55/20,
Old 08-14-2010, 11:29 AM
Rep:4085
I haven't heard of it causing the CEL to come on, but perhaps someone else on here has.
Old 08-14-2010, 11:52 AM
Haven't seen the 180 do it on the HEMI, have seen a 170 do it, though.
And it only happens when ambient temps are low and the vehicle is not warmed up before driving.
You'll be fine with a 180. I've been runnin' one in my SRT8 for 3 years with no codes at all.
Old 08-14-2010, 12:01 PM
rdsabin rdsabin is offline
Vehicle: 2012 Sport Reg Cab 4x4
Trim Level: Sport Reg Cab
Color: Mineral Gray Metallic
Rep:186
rdsabin has a spectacular aura aboutrdsabin has a spectacular aura about
I run a 180 on the Super Bee with no problems. I just set the fan settings with the predator to adjust for the cooler thermostat.
2012 DodgeRam 1500 4x4, 20% Tint, Running Boards, Class IV Hitch, 14" Win Muffler, Catch-Can, Tow-Hooks, LED Tailgate Bar
2008 Dodge Supe Bee, Catch Can, Backup Camera, 20% Tint all windows, CAI, AFE Filter
Old 08-14-2010, 12:05 PM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 1492 Santa Maria
Color: Hot pink
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
From what I've read, the 6.1's are more prone to have that issue than the 5.7's,,,
With that being said, the large majority of the 6.1 owners are not having any issues with MIL /CEL and their 180 stats.
Old 08-14-2010, 01:33 PM
Color: Cool Vanilla
Rep:63
Ok ill have to give it a shot. I dont have a programmer yet. hopefully the cel wont come on.
Old 08-14-2010, 05:58 PM
liljohn30's Avatar
liljohn30 liljohn30 is offline
Vehicle: 08 lonestar hemi ram qc
Color: white/gold
Rep:13
liljohn30 is on a distinguished road
dont mean to hijack but do you have to drain the coolant to do this..i wanna put my 180 stat in.i see the upper radiator hose and i think that is where the stat is,iit dont looki like it goes on the lower rad hose
Old 08-14-2010, 06:23 PM
It is in the upper rad hose housing into the engine. Get you a gallon sized plastic back, back off your bolts, hold the bag under the housing and catch the dexcool that comes out. You can put it back into the system at the recovery tank.
Then pull out your tstat. check the rim of it for a small o-ring and a groove in the tstat disk. Now check your 180 for a groove and o-ring. If you have both, you are good to go. If you only have the groove but no o-ring on the new tstat, re-use your old one.
Old 08-14-2010, 06:25 PM
Rep:4085
Yep, Michael nailed it, you only have to drain the coolant to below the level of the T-stat and so long as the coolant is still good, by all means, re-use it.
Old 08-14-2010, 10:19 PM
Color: Hot pink
Rep:135
Leave the rad cap on and the 'vacuum/airlock' in the system will only allow at most a couple quarts to come out,,,, Do the 'bag trick' like Maddod said,,
