Old 08-14-2010, 02:12 PM
tnwtrboy tnwtrboy is offline
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
tnwtrboy is on a distinguished road
Default 96 Ram Horn
I recently bought a 96 Dodge Ram. The Horn doesnt work. I check the horn wires and the horns are still wired up. I checked the ends of the wires and theyre disconnected. I can touch these to the positive and negetive sides of my battery and the horns work. When I press the horn button, I can hear the #5 relay clicking under the hood. Where do i need to connect these two loose ends to make the horn work off the horn button on the steering wheel?
Old 08-14-2010, 03:07 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
This will take two people.
First look around the engine compartment for where those wires were cut from. Start at the fuse/relay box.
Second, when you locate the wires, connect a volt meeter to them and have someone press the horn button. This will confirm those are the wires you are looking for.
Once you have found them, splice the wires leading from the horn to the wires you've just found.
If you don't find the wires, you will have to attach the wires you have back to the fuse/relay box.
Brian:
