Old 08-14-2010, 08:31 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Default AVS In-channel Slimline Vent Visors installed today!
Got a set of AVS Slimline in-channel Vent Visors today thanks to Casualdreamer of the ForumZ here! Anyone need AVS in-channel Slimline Vent Visors...
Install was a breeze! Having applied the regular Vent Visors numerous times, this was actually easier, and a cleaner look in my opinion.
First what was in the package, the visors, a Scotch Brite scratch pad, alcohol wipes, and the instructions didn't make it out to the truck (who needs those anyways, right?):
We start by lowering the windows enough to get the visors in without any clearance issues:
Using the Scotch Brite scratch pad, rub the felt lining inside the window channel to give the adhesive tape a proper surface to stick against:
Then using the alcohol wipes you want to wipe the channel as well so the surface is free of anything that might hinder proper application of the adhesive tape:
Removing the red liner from the adhesive tape, you can then snug the Visor into place. It is easiest to start with the side towards the mirror, then by applying a VERY slight bend to the visor, the back side towards the rear window will slide right into place. There is not enough pressure on the Visor at this point for it to have stuck to the felt lining, so you can then press it firmly up into the channel:
Old 08-14-2010, 08:32 PM
chithead's Avatar
Rep:2078
Assure that the window won't have any issues when raising, and then bring it on up!!!
Passenger side done as well:
Quick tip, to avoid the felt lining applying a nasty burn to your finger when rubbing that alcohol wipe in there, drape it over your finger like this:
Learned that one the hard way...
Old 08-14-2010, 08:36 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Nice how-to.
Brian:
Old 08-14-2010, 08:40 PM
chithead's Avatar
Rep:2078
Couldn't resist a few quick snap shots of the R/T, please forgive her dirty condition...
Old 08-14-2010, 08:43 PM
MADDOG MADDOG is offline
Rep:22
Nice work, Daniel. How's the finger? ;
Old 08-14-2010, 08:55 PM
chithead's Avatar
Rep:2078
It's better now. That alcohol being pressed into the burn really helped out
Old 08-14-2010, 11:09 PM
Casualdreamer's Avatar
Casualdreamer Casualdreamer is offline
Vehicle: 2010 Ram 1500 Screw
Color: Blk
Rep:95
Casualdreamer will become famous soon enough
Man, they told me Monday they would be there. I am glad you got them already. They look really nice. Awesome write up..
Hi my name is Mike and I have a Ram Sport CC...
Mods: GoRecon Projector Headlights BLK,GoRecon Tail Gate Lightbar, GoRecon LED Tail Light BLK, GoRecon 3rd Brake Light, GoRecon Big Rig Kit, 8K H.I.D Kit, L.E.D Light Bulb Swap Throughout, 6" BDS Lift, 37X12.5X18, Fuel Gauge Rim, Westin Bull Bar
Old 08-14-2010, 11:30 PM
Rep:1625
They look great! Nice addition!
Old 08-15-2010, 02:38 AM
Nice Daniel . Nice write up and they do look great . Rep ya .
Old 08-15-2010, 08:08 AM
chithead's Avatar
Rep:2078
Thanks! I am really appreciative of them. Should come in handy this fall and winter!
