AEM brute force issue - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 08-15-2010, 12:09 AM
tdawgg tdawgg is offline
tdawgg is on a distinguished road
Default AEM brute force issue
Hi,
Today I had a garage install an aem brute force cai.
I got home and wanted to show my wife the new cai(3 hrs later) and noticed that my coolant level was at the add line. I just had my oil changed and all fluid levels were great.
Could this of happened during the install?
Any info would be appreciated.
Old 08-15-2010, 12:17 AM
RammD RammD is offline
Vehicle: 2010 RAM SLT REG. CABX2
Color: CRYSTAL BLACK PEARL
Rep:61
RammD will become famous soon enough
I did this install on my 2010 R/T a couple of weeks ago. The CAI should have absolutely no bearing on your coolant level at all. Did you see a leak somewhere? How does it sound when it's running? I would just watch the coolant level the next couple of days and add water if you need to but if you don't see any leak then you probably didn't damage a hose by mistake so I think it's just a coincidence.
Old 08-15-2010, 01:21 AM
Maybe coolant leaking into the gaskets then? Oil is clear, will check for smoke in morning.
Old 08-15-2010, 01:24 AM
I can just add water to the res? I live in canada, but its summer here... should be no issues, eh? lol
Old 08-15-2010, 08:58 AM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
Originally Posted by tdawgg View Post
Hi,
are you sure you didnt pull the wire for the coolant
i dont think did you for some reason drain the coolant
ya you should be fine
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 08-15-2010, 09:51 AM
Started it up this morning and a tiny bit off white smoke right after ingnition, but nothing substantial.
No smoke but there is drops of water coming out the the magnafows when i rev to 3000 rpm.
Oil is clear.
Old 08-15-2010, 09:55 AM
Condensation is normal in the exhaust system. It does not mean you are losing coolant.
Was the engine cold when you noticed the coolant level?
Old 08-15-2010, 10:05 AM
3 hrs after running, but my driveway is on a grade, went down to the road and the coolant is up a bit but still pretty much at the add line.
I hear a little knocking, but ive always heard a little knocking from the time i bought it. Ive read that hemis are known for this.
Old 08-15-2010, 10:29 AM
My OBD2 isnt picking up any codes at all. Would it be picking up something if there was a major problem?
Old 08-15-2010, 11:44 AM
So when I ren theres no smoke at all but when the rpms go back to idle i see a little white smoke.
Sorry for all the questions guys.
