Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Dodge Ram Decals
Old 08-14-2010, 06:49 PM
JKVDK JKVDK is offline
Vehicle: 06 Dodge Ram
JKVDK is on a distinguished road
Default Got a squeak.
I hopped in my truck today to go wash it and i had the window down and noticed a higher pitched squeak/grinding noise(almost the same sound as squeaky brakes). The noise didnt change when i turned the wheels and it stopped when the truck stopped.I am wondering if it is a wheel bearing, anyways I was just curious if any of you guys had any insight into this issue.
Old 08-14-2010, 07:12 PM
Either a bearing or one of your disc brake pads is dragging, a sure sign that the slide pins in the caliper are stuck.
Old 08-14-2010, 07:23 PM
Mmmmmk I had the truck lifted about two weeks ago and now it has a pull to the right even after an alignment could that also be related?
Old 08-14-2010, 07:24 PM
RootBeer RootBeer is offline
Color: RootBeer
Rep:1287
Far to often when people do brakes, they don't lube those slide pins.
Brian:
Old 08-15-2010, 02:04 AM
Wheel bearing would be more of a rumbling noise . Not high pitched
Old 08-16-2010, 06:33 PM
Tebos04 Tebos04 is offline
Tebos04 is on a distinguished road
Check u-joints. I had one last week making a pronounced squeaking noise along with a vibration. Replaced the rear and all is well.
