Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Recalls and TSB's.
Old 08-16-2010, 11:05 AM
Rep:1885
Default 2010 Recall - K08
2010 (DS) Ram Truck (1500 Series)
NOTE: This recall applies only to the above vehicles built at Warren Truck Assembly Plant (“S”
in the 11th VIN Position)
equipped with an automatic transmission (sales codes DGQ, DGV or
DF9)
from January 11, 2010 through February 4, 2010 (MDH 011106 through 020411).
(DJ) Ram Truck (2500 Series)
(D2) Ram Truck (3500 Series)
NOTE: This recall applies only to the above vehicles built at Saltillo Assembly Plant (“G” in
equipped with an automatic transmission (sales codes DGQ, DGV, DG7
or DF9)
from January 6, 2010 through February 16, 2010 (MDH 010606 through 021616).
2010 (LC) Dodge Challenger
(LX) Chrysler 300
NOTE: This recall applies only to the above vehicles equipped with an automatic transmission
(sales codes DGJ or DGV)
built from January 18, 2010 through March 11, 2010
(MDH 011807 through 031113)
2010 (WK) Jeep
® Grand Cherokee
(XK) Jeep
® Commander
(sales codes DGJ or DGQ)
built from January 8, 2010 through February 13, 2010 (MDH
010804 through 021307)
IMPORTANT: Many of the vehicles within the above build period have already been
inspected or repaired and, therefore, have been excluded from this recall.
The Wireless Ignition Node (WIN) receiver on about 37,000 of the above vehicles
may experience a condition where the Frequency Operated Button Integrated Key
(FOBIK) may be removed prior to placing the automatic transmission gear shift
lever in the “PARK” position. This could result in unintended vehicle movement
and cause a crash without warning.
The Wireless Ignition Node receiver must be inspected and replaced if necessary.
The new WIN must be programmed and all FOBIK transponders must be
programmed so they are able to interface with the new WIN receiver.
Vehicles equipped with a premium Tire Pressure Monitoring (TPM) system
sales code XGM) must also have the spare tire pressure sensor identification
number and location programmed into the new WIN receiver.
NOTE: Be sure to ask the customer to bring in all FOBIK transponders for
the vehicle. At least two FOBIK transponders must be programmed before
the vehicle can be operated.
Old 08-16-2010, 08:29 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Thanks for posting these bulletins.
Brian:
Old 08-16-2010, 10:26 PM
Rep:1885
Glad to help.
Old 09-03-2010, 05:09 AM
charlie3133's Avatar
charlie3133 charlie3133 is offline
Trim Level: SLT Plus
charlie3133 is on a distinguished road
I just got my notification for this one.
If you are what you eat then I am fast cheap and easy!
Old 10-03-2010, 09:07 PM
rainhater1 rainhater1 is offline
Vehicle: 2010 ram 1500 4x4 06 300 srt8
Trim Level: slt - big horn
Color: light graystone
Rep:116
rainhater1 will become famous soon enoughrainhater1 will become famous soon enough
Default vin #
Originally Posted by RamTech View Post
Glad to help.
Is there a way to put your vin number in and find out all the tech and recalls?
Old 02-25-2011, 02:44 PM
budrust budrust is offline
Vehicle: 2010 Ram 1500 4wd Laramie
budrust is on a distinguished road
my local dealer says I need the WIN replaced to solve a problem that killed my speedo and caused a whole lot of dash warning lights to come on. They also tell me the part is not available. It's a 2010 Ram made at the Warren Plant and should have been repaired once already. I bought it new a few weeks ago and have 600 miles on it.
Old 02-25-2011, 03:13 PM
Rep:1885
For some reason, WIN modules have been hard to come by recently. I'm not sure if it's due to the failure rate, a supply problem or both. I do know that a different vendor now makes the WIN modules.
