Old 08-17-2010, 08:13 PM
tinniste 079 tinniste 079 is offline
Vehicle: 2005 dodge ram 1500
Color: charcoal grey
Rep:53
tinniste 079 will become famous soon enough
Default ticking from left side of the motor
anyone else notice this on there 4.7?
mines got almost 90k on it and it ticks so bad most annying thing in the world!! lady in the service department said its the valves most likely.
Old 08-17-2010, 08:19 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Take an empty metal soup can. Glue a long but small metal (steel preferably) prong onto the bottom. Put the prong against the valve cover and your ear over the open end. It will tell you whether it's in the valve train.
Or, just go buy an automotive stethoscope which just takes all the fun out of making it. lol
Might check plug wires at night to see if they are arcing against anything.
Brian:
Old 08-20-2010, 11:25 PM
RamItAll's Avatar
RamItAll RamItAll is offline
Vehicle: 2002 Dodge Ram 1500
Color: Blue
Rep:85
RamItAll will become famous soon enough
my F**D does that. check your lifters
Old 08-21-2010, 10:09 AM
ram06bighorn's Avatar
ram06bighorn ram06bighorn is offline
Vehicle: 06 RAM 1500
Trim Level: Big Horn SLT
Rep:37
ram06bighorn is on a distinguished road
My 06 Does it when I first Start it up. then quites after a couple min. of running
Old 08-21-2010, 11:12 AM
Rep:1877
The first gen 4.7 doesn't have wires.
Old 08-21-2010, 06:45 PM
benbob benbob is offline
Vehicle: 2004 Dodge Ram QC Long box 2wd
Color: Silver paint code ps2
benbob is on a distinguished road
Did you check the exhaust manifold and y-pipe for leaks? Sometimes an exhaust leak can sound like a lifter tic. Especially check the the left rear ex. manifold bolt. I've seen it alot.
~ BEN
Old 08-24-2010, 01:50 AM
RamItAll's Avatar
Color: Blue
Rep:85
hopefully with all this input you find it. good luck
Old 08-24-2010, 01:57 PM
4pnt7 4pnt7 is offline
Vehicle: 2008 4.7l Dodge Ram
Color: Graphite Grey
4pnt7 is on a distinguished road
The 4.7l doesn't have lifters. We have hydraulic lash adjusters. after so many miles they get dirty and they don't open properly. This causes the ticking. Well this is what ive been told. Lol! They make a solid lash adjuster and a hydraulic lash adjuster. Hydraulic ones come stock and work real well. I have a friend that purchased the solid ones and says they are a PAIN you wont like and expensive . He end up buying a new set of hydraulic ones.
I'm not saying this is your problem. Like some sayed above that it could be an exhaust leak, cheap oil, ect.
Nicolas Chavez
2002 ram 4.7l qc (Totaled),60ft.-2.0,1/8-9.310,@76.mph,1/8-9.41,1/4-14.80,@90.94
Old 08-25-2010, 11:58 AM
mortelec's Avatar
mortelec mortelec is offline
Vehicle: 2010 Dodge Ram Quad Cab
Rep:20
mortelec is on a distinguished road
I think this is fairly normal for the 4.7. My 03 had a tick from new to 150,000 miles. It was getting a little loud at 150xxx when I sold it. I never had any motor trouble the dealer said it was pretty normal.
Old 08-25-2010, 02:01 PM
ya I think your right about ut being a normal thing. But It should go away after it warms up. Mine would tick when I would first start the truck but would go away in a few minutes. After 100,000 it got worse. I never did change them but I'm sure if I would have the engine would have sounded better.
Nicolas Chavez
