Old 08-18-2010, 09:33 AM
DaSOB's Avatar
DaSOB DaSOB is offline
Vehicle: 1998 Dodge Ram Ext Cab
Trim Level: SLT Laramie
Color: Light Driftwood Satin Glow
Rep:51
DaSOB will become famous soon enough
Default Scraping noise in steering column
I have a 98 Ram, and I'm getting a scraping noise inside the steering column which is more noticeable the faster I turn the steering wheel. I've had the plastic column covers off, but the scrape seems to be coming from farther down in the column.
Any idea what may be causing this, and what can be done about it?
Thanks!
Ah Luv Muh Truck!!
http://www.ramforumz.com/signaturepics/sigpic2117_1.gif
Old 08-18-2010, 01:04 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Don't know the answer on this one, sorry. But this will put it back to the top.
Brian:
Old 08-18-2010, 01:10 PM
DaSOB's Avatar
Rep:51
I had run this by a Dodge mechanic on Just Answer, and he said that it could be an internal bushing that has gone dry. I tried shooting some silicone lube down in there but it didn't help. Is it possible to disassemble the steering column assembly without really messing things up? If it can be pulled out of the sleeve, perhaps the cause could be found.
Ah Luv Muh Truck!!
Old 08-19-2010, 02:17 PM
808 KUMA's Avatar
808 KUMA 808 KUMA is offline
Vehicle: 2009 Ram
Trim Level: SLT,Crew Cab,Ram Box
Color: Mineral Grey Metalic
Rep:111
808 KUMA will become famous soon enough808 KUMA will become famous soon enough
I'm not sure if this will help but, my son's (2001-2500 w/250,000 miles) has the same problem for the same reason and the info he got was; It's not rebuildable and a new one (column)is expensive. He did drill a hole in the skin and squirt some lube in and it did get better. The column is pressed together during assembly and can not be rebuilt is what he was told. Hope this helps-ya.
Custom Grill,Airaid. E-3 plgs. Spintech catbck. Stainless Smittybuilt Nerf's. E-Z gate. Putco mirror cvrs. Fire & Ice LED tailgate strip. LED eng.bay lights. 20" Wheels. Ramheads LED's. Clear LED Tail lights. Fog Lights.15" Night Raider Strobe in lower grill. Chrome Diff. cover. Red brake-calipers. Polished drive shaft. MOPAR Soft Tonneau cover. Stainless pillar post covers. Mopar-Chrome gas cover. Stainless window-sill trim. Clear LED 3rd Brake Light. Mopar Slush-Mats. "Wet-Suit" type seat covers(Red-on-Black) Custom Ram-Strpe on rear fenders.
Old 08-19-2010, 02:19 PM
DaSOB's Avatar
Rep:51
Thanks, 808 kuma! As long as I know it's not something that's going to cause the steering column to fail or lock up, I can deal with it. I'll try drilling through the sleeve and shooting some silicone lube into it.
Thanks again!
Ah Luv Muh Truck!!
Old 08-19-2010, 04:24 PM
Rep:4072
Interesting. I still have that annoying click in my column and so far, no one has been able to explain a cause or a fix.
Old 08-19-2010, 06:11 PM
I would probably spray some type of spray grease . Silicone spray won't last very long .
Old 08-19-2010, 08:11 PM
DaSOB's Avatar
Rep:51
Good point. Can anyone suggest a good brand of spray lube or grease?
Ah Luv Muh Truck!!
Old 08-19-2010, 09:40 PM
Zep makes a high adhesion grease called PL2000 . I use that at work and home . I believe Home Depot does sell some Zep products .
Old 08-19-2010, 10:00 PM
DaSOB's Avatar
Rep:51
Thanks, Tom. I'll check that out.
Ah Luv Muh Truck!!
