Old 08-18-2010, 11:45 AM
bikequad4x4 bikequad4x4 is offline
bikequad4x4 is on a distinguished road
Default 2500 to 1500 axle swap
Hi I have a 1996 Dodge Ram 2500 (parts truck) that I would like to remove the rear end and install it in my 1998 Dodge Ram 1500. Can I just swap the axles out so I can use my rim that are now on the 1500? The 2500 is an 8 lug and the 1500 is a 5 lug. let me know if you have any ideas
Thanks
Bob
Old 08-18-2010, 02:00 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Chances are the rims won't work on the 2500 axle.
Brian:
Old 08-19-2010, 11:39 AM
kicknjeep kicknjeep is offline
Vehicle: 1995 Dodge Ram 1500
Rep:26
kicknjeep is on a distinguished road
if you asking if you can put the axles from the 9.25 into the D60 I believe the answer is no due to different shaft thickness/diameter.
Rem will be along in a minute to give a more detailed answer!
Old 08-19-2010, 11:58 AM
Rep:1877
Nope. Your 2500 axle is a full floating axle. The 9.25 is not.
Old 08-19-2010, 08:07 PM
I agree with Randy . Totally different set up .
Old 08-19-2010, 08:09 PM
Color: RootBeer
Rep:1287
I think the question was whether a 2500 rear end will fit under a 1500 and if the 1500 wheels will work on the 2500 rear end.
Brian:
Old 08-20-2010, 07:13 PM
Default axle swap
I have received my answer...Thanks Guys!
So If I want a better rear rend what should I go with. I would like to in the future change the ratio in both the ront and rear due to the 39.5 rubber I'm running. I know I have a Dana 40 in the front.
Old 08-20-2010, 08:04 PM
With the bigger tires I would consider putting a pair of Dana's under it . Yes you would have to change your rims also .
Old 08-22-2010, 01:52 AM
ScatPak07's Avatar
Rep:970
Really anyhing is possible. There are custom rear axles that you can buy off of 4wd sites. I am not too familiar with axles and all of that I am still trying to learn. Really if you have the time and money you can do anything.
I have seen on Extreme 4x4 (Powerblock T.V) they put 2500 axles on a 1500. If you know how to do it then it is possible. I think I even have that in a magazine now that I think of it. I will look when I get a chance and maybe send you a scanned copy of the DIY of the axle swap!
