Old 08-18-2010, 04:20 PM
wremote's Avatar
wremote wremote is offline
Vehicle: 1972 Dodge Dart Swinger
Color: Machetti Lime Green Metallic
wremote is on a distinguished road
Default Using a 5.2l ecu on a 5.9l
Hi, I have a 1995 5.9l installation and have had to temporarily resort to using a 5.2l ecm.
are there any differences other than performance between the two?
Thanx
Not numbers matching but 97% MOPAR
Old 08-18-2010, 04:34 PM
Thats about it . It will work but I'm sure the specs between the two are different . Did you swap out the 5.2 for the 5.9 ?
Old 08-18-2010, 07:35 PM
wremote's Avatar
No, I have installed a 5.9l in a 72 swinger and am using a 1995 ecu because I want OBDC1. I had bought a 95 ecu and was told it was for a 5.9l, as it turns out it was for a 5.2l. I just want to get it running and set up before a buy an ecu for a 5.9l. I am having some issues though. I am not getting voltage to the Inlet air temp sensor and it goes into automatic shut down after a couple of minutes.
Old 08-18-2010, 11:27 PM
Remember the 5.9's are externally balanced . Make sure you have installed the correct torque convertor or you'll have a bit of a vibration .
Old 08-19-2010, 09:21 AM
wremote's Avatar
One more question.
This may sound silly but would it be possible to use an ecu for a standard shift. The transmission I am using is a 518 from a 92 Dakota without a lockup torque converter. The OD is controlled manually.
