Motor Mounts Replacement Question 4.7L 2WD - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-18-2010, 05:36 PM
tazsafety's Avatar
tazsafety tazsafety is offline
Vehicle: 2002 Dodge Ram 1500 2WD
tazsafety is on a distinguished road
Default Motor Mounts Replacement Question 4.7L 2WD
Does anyone have some advice on how to replace the motor mounts? If someone has done this, please give me some advice on how to properly and safely replace the mounts. Do I need to get a engine crane? Can the engine be lifted using a floor jack? Where should I place the support under the oil pan or somewhere else? Any advice? Thanks
Old 08-18-2010, 05:44 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
It can be jacked up. Do NOT put the jack under the oil pan or tranny pan. You will need to unbolt both the engine and tranny. You should only have to jack it up an inch or so. Just enough to get at the bolts holding the mount to the block. Take out the block mount first then the frame mount. Put the new ones in, in reverse order. Have someone lower the assembly until you can easily slide the cross bolt back into the two mounts and do the same with the tranny. Once all bolts are in place, tighten and drop the jack.
Brian:
Old 08-19-2010, 02:58 PM
tazsafety's Avatar
Thanx for the reply RootBeer. I have some questions. If I can't place the jack under the oil or tranny pan, then you are saying that I have to use a motor crane? I was looking at my engine and I have no where to place the hook to the engine to be lifted. Friends of mine are saying to use a piece of wood to place it under the oil pan and jack up the engine. The repair manual said to use a crane.
Old 08-19-2010, 06:25 PM
Color: RootBeer
Rep:1287
Check between the block and tranny. Put a block of wood on the jack. Or using the same wood, look just forward of the engine oil pan where it bolts to the motor. The pan itself is not strong enough to hold the weight.
Brian:
Old 08-20-2010, 01:27 PM
tazsafety's Avatar
Thanks RootBeer for the info. This weekend I will look under the engine and get busy replacing the mounts. I thought it will be a good time to pain the mounts too. Thank you again RootBeer, I will post pics of the replacement. -Taz
Old 09-15-2010, 01:56 PM
tazsafety's Avatar
RootBeer, thanx so much for the information you have given me to help me replace the motor mounts. This passed weekend, I finally replaced the mounts and real HAPPY with the results. Here are some pics of the mounts. Thanks again, -Taz
Old 05-07-2017, 05:03 PM
BRAWNEY BRAWNEY is offline
Vehicle: 2006 RAM1500 5.7L
Trim Level: BASE
Color: WHITE
BRAWNEY is on a distinguished road
Default 5.7l motor mounts
hey guys, trying to put my mounts back on after having my heads replaced. its two months later and i can't figure them out!! they go on either side AND can fit side up and upside down! please help with pictures, thank again in advance!!!!!
