Latest Vendor News |
| Dodge Ram Accessories! |
08-18-2010, 11:17 PM
Vehicle: 2006 Ram 1500 4X4
Trim Level: Laramie -tow package
Color: red
Rep Power: 4 Rep:78
Replace EGR valve P1404
I had a P1404 EGR Valve Closed Pintle Position code on my 2006 dodge ram 5.7 Hemi. I went to the dealer and bought a new egr valve and installed it myself and now all is good.
It was very simple to replace, it is located just below the altenator
slide the red clip on the electrical connector to the right, from this
to this
then use an 8mm 1/4 inch drive deep socket to undo the egr to intake tube
then use a 10mm 1/4 inch drive deep socket to remove the 2 bolts that mount the egr to the engine. Re install the new egr valve in the reverse order. Only took about 40 minutes.
2006 4X4, 5.7 Hemi, MDS with 3.55 gears, 2" daystar level, 20" eagle alloy's with 35's
08-18-2010, 11:21 PM
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Did you clean the return tube with some brake parts cleaner?
08-18-2010, 11:22 PM
Vehicle: 2011 Chevy 3500HD
Great how to post.
Brian:
Nice writeup! Thanks
RamForumz.com | Dodge Ram Forum | Dodge Ram Forums | Dodge Ram Performance | Dodge Ram Accessories | Custom Dodge Ram | Dodge Truck Forum | Ram Truck Forum
08-18-2010, 11:23 PM
Color: red
Rep Power: 4 Rep:78
Yes I cleaned it out with brake clean.
08-18-2010, 11:25 PM
Color: red
Rep Power: 4 Rep:78
sure was nice to see it was located right at the front of the engine in easy reach and not stuck up in the back.
09-21-2010, 11:54 AM
Rep Power: 0 Rep:10
I have a 2004 Dodge Ram 4.7L 1500.......is there an egr valve on this vehicle.....Haynes manual says it behind the manifold,but I can't locate it!?
09-22-2010, 05:11 PM
Color: red
Rep Power: 4 Rep:78
I found this for an 05 4.7, should be the same.
Its located on the rear of the driver's side head. Its actually very bad to change.
If you look at the left side of the plastic intake manifold, a bit to the rear of the throttle body you will find a metal tube coming off, it makes a 90 deree bend to the rear. Follow this tube to the rear of the left head, and you'll find the egr valve. Its in about the most horrible spot you could imagine. You'll have to lay on the engine to replace it. A drop light is a must.
The EGR tube comes into the left side of the valve. It has 2 8mm bolts that hold it on. I always use a 1/4" drive 8mm swivel socket and a 3" extension. There really isn't much of a choice. Be careful when you get about done removing it, the gasket may fall and your new valve won't come with one. There's an alternate way to get the tube off, I'll get to that.
To remove the valve from the head you have to remove 2 10mm bolts. The bolts go straight down from the top. Don't bother looking for them, you have to feel for them.
The other thing you can do is remove the 2 bolts that hold the valve to the head and remove the valve and tube together. When you put it back together you have to leave the tube loose from the valve or you'll never get the bolts back in the valve-to-head joint.
09-22-2010, 05:22 PM
Nice job sablefish, great help there in finding that info!
CajunDodge - 2008 Dodge RAM 1500 ST SWB, Bright Silver Metallic, Magnum V-6; 1991 XJ JEEP Cherokee Sport 4x4, 4L H/O I6 the only one!
02-11-2012, 07:19 AM
Vehicle: 2006 Dodge Ram 1500
Trim Level: SLT Big Horn Edition
Color: Patriot Blue Metallic
Rep Power: 3 Rep:10
Excellent write up! Although I did not clean my EGR valve. I went to Advance Auto and bought a new EGR valve for $39.99 and it comes with a lifetime warranty. Thank you so much for posting this!
Dan R.
SGT, US Army
2006 SLT Big Horn
