Old 08-20-2010, 10:39 PM
gregster's Avatar
gregster gregster is offline
Vehicle: 2014 Ram Crew Cab
Rep:81
gregster will become famous soon enough
Originally Posted by brvheart View Post
^ do you ever pull through the hills or mountains? I would be interested in your experience there - that is really the only place I fear I will be unhappy.
I am in the same exact boat as you on this....I have done a dis justice to the mighty HEMI....
I live in Toronto, so its not exactly mountainous here.
Having said that, the hills I have towed across are handled effortlessly. As you see in the attached photo, the trailer I use is not exactly huge (although we pack it so heavy that we have blown out the trailer wheel hub twice!)
Ambitious, but rubbish!
Old 08-22-2010, 09:50 PM
Ray's Avatar
Ray Ray is offline
Vehicle: 2010 Dodge Ram 1500 Crew Cab
Rep:45
Ray is on a distinguished road
I can't find my sticker, does anybody know how to tell what gears you have?
Mods:Mopar fiber glass Tonneau cover,Nerf Bars,Bully Hitch bar,husky mud guards,stubby antenna,Edge guards,weather mats,20%tint all around+windsheild,lisence plate covers,Upgrage to REN w/back up cam,Magnaflow 18, putco bulbs,LED interior/plate bulbs,viper smartstart
Old 08-22-2010, 09:51 PM
jonnyriabov jonnyriabov is offline
jonnyriabov is on a distinguished road
I pull a 29' travel trailer b-trained with a 14' boat trailer with my 3.55 gears. I always use the tow/haul mode and it holds gears no problem except on the really steep hills where it will kick down a gear mid hill.
I wouldnt worry to much about it, unless you hauling on a daily basis
Old 08-22-2010, 10:54 PM
brvheart's Avatar
brvheart brvheart is offline
Vehicle: 2010 Ram 1500 Crew Cab
Color: Mineral Gray
Rep:34
brvheart is on a distinguished road
^ seriously?? I need to see pics of that! That is a huge testament to the RAM and 3.55.
Old 08-22-2010, 11:24 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Does anyone remember when transmissions didn't have OD. A time when a 7+ liter engine made under 300hp. A time when you wouldn't even consider 3:92 or 4:10 gears unless you were trailering the Titanic daily.
I remember one. my 1983 Ford F250. 460 (225hp, 380lb/ft), 4spd, 4:10gears. Top speed - 85mph. At 60mph, the tack was at 3100 rpm. 10.5mpg (imperial). What's that....about 8.5mpg (US). Pulled like a banshee!
Now I have a 5.7L (345cid) with 390hp and 3.92 gears. Top speed - unknown, but better than 100mph. At 60mph, the tack is at ~1800rpm. 10.5 - 26mpg (Driving style dependent). Pulling similar trailers, it out performs my old Ford so greatly, the Ford might as well have had the 302 with 2.73 gears.
Even with 3:55 gears, you can choose to not use 1 or both of the OD gears, and it will still out perform most yesteryear trucks.
For pulling a boat around a few weekends a year, the 3:55 gears are perfectly fine. If you were pulling the trailer more than not, I would recommend the 3:92 option. Either way, IMO you have nothing to worry about....either gear set will work well for your application.
Enjoy the performance that many years of technological improvements have brought to the car lot.
brad
Interested in one of my mods?
Old 08-23-2010, 01:28 AM
UnLiMiTeD UnLiMiTeD is offline
Trim Level: SLT Crew Cab 4x4
Color: Deep Water Blue Pearl
Rep:0
UnLiMiTeD is an unknown quantity at this point
I got to say, the difference betwen the two gears is not night and day like some claim it to be. I drove 4 different rams before buying mine. 3 of them were sports with the 3.92 gears and 1 was an slt with the 3.55. I end up buying the SLT because it had the options that fit me better. BUT when i bought it, i forgot to check the gear ratio on it, assumed it was the 3.92 like the other 3 and did not find out until after that it wasn't the 3.92.
I was a bit dissapointed at the beginning when i found it out but i also didn't even notice the difference when test driving the 4 trucks. When towing heavy loads im sure i would, but for day to day driving with a light load, 3.55 gears have plenty of kick to them.
Thats my thoughts on it, if your doing mostly unloaded driving and the rare tow on a medium weight load, i really wouldn't worry about it. Not supposed to be racing around when towing loads anyways lol.
Old 08-23-2010, 01:46 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Call the dealer with your VIN.
Brian:
Old 08-23-2010, 11:38 AM
brvheart's Avatar
Color: Mineral Gray
Rep:34
so just for those that have not seen it or want to look, here is the 2010 Bodybuilder guide from Dodge with trailer max with tire sizes
http://www.dodge.com/bodybuilder/201...ammlup1500.pdf
Also after doing some more research - I found the following on another forum -
For the 2009 4x4 Crew Cab with 20-inch footwear...
With the 5.7L and 3.55 axle:
- GCWR is 12,000, maximum trailer weight is 6300
With the 5.7L and 3.92 axle:
- GCWR is 13,000, maximum trailer weight is 7300
With the 4.7L and 3.55 axle:
- GCWR is 10,500, maximum trailer weight is 5750
With the 4.7L and 3.92 axle:
- GCWR is 11,500, maximum trailer weight is 5950
Remember that the weight of people and gear in the cab have to be subtracted from the maximum trailer weight. Hope that helps!
So looking at that, you are getting an additional 1000LBS with the 3.92 gears vs the 3.55 using the same motor and wheels/tires
hope this helps someone.
Old 08-23-2010, 12:37 PM
kutect's Avatar
kutect kutect is offline
Vehicle: 2009 Dodoge Ram
Trim Level: Crew 4x4 Big Horn
Rep:24
kutect is on a distinguished road
I have lifted my truck with 4" and 35 inch tires, with 3.55 gear, and im getting around 16 on freeway miles. On paper it's 18 on freeway. Of course i have CAI and Exhaust installed. MPG is great, but it's way slower then the original height and size tire. Don't do much towing, but really thinking about switching out the gear to 3.92. Just not sure if it's going to get back the factory speed. Before all the mods, i was able to take out my friends 07 Ram by half of a truck. Now, i lose to him by a WHOLE truck lenght....but my truck looks better than his.
Mopar: 4" lift kit/cold air intake/dual exhaust/tublar step bar/35" BFG KM2 tires/RBP 95R wheels
Old 08-23-2010, 01:02 PM
brvheart's Avatar
Color: Mineral Gray
Rep:34
does anyone know if it kills the factory warrant if you have the dealership swap the gears?
