Old 02-27-2011, 07:25 PM
PITA PITA is offline
Vehicle: 2009 Dodge Ram Quad Cab 4x4
Color: Two tone tan
PITA is on a distinguished road
Originally Posted by Zeus1977 View Post
I just got a 2011 with 3.92 & I am only avg. 12.8mpg perhaps I have had my foot in it a little or it needs to break in not sure, but we will see.
That's lousier than I would have expected with a 3.92, and certainly worse than my 3.55.
I tow as much as 6000 pounds with my 3.55 and I have zero complaints. A 3.92 may be better for towing, but then again so would a diesel...
But nothing wrong at all with a 3.55 as long as you stay well within the capacities.
The worse thing about the truck is the fuel ecomomy, why would I want to make it worse?
Road King Classic, VFR1200, Fireblade, DRZ400SM
Ram Laramie Quad 4x4, RX8, 128i Cab
Old 02-27-2011, 08:39 PM
dafoot dafoot is offline
Vehicle: 2011 Dodge Ram, 1500, Hemi
Rep:16
dafoot is on a distinguished road
I have to disagree. The worse thing about the truck with 3:55s is the constant shifting! I am glad you are happy with your set up.
DAFOOT
Old 02-28-2011, 11:13 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
I have the 3:92's, and I have a few friends with the 3:55's. Some are 2wd, most are 4wd.
Of them all, I am the most aggressive driver (I didn't but the Hemi for the mileage), and pull the heavier trailers....more often. Surprisingly, I have the best over all gas mileage.
Recap -
I drive harder.
I pull more.
I beat them in all races.
I have the best gas mileage.
Gezzz, I'm a frig'n freak!!
Overall driving style will affect your mileage much more than the gearing difference will. If you do a lot of towing, there definitely are fuel saving benefits to the 'taller' gears, as it allows the engine to turn slightly faster, with a slight less torque demand, which often equates to running in a higher gear. When I ordered my truck, I was very aware that my intended use would be best served with 4:10 gears, but since that is not an available option from the factory, I chose the closest ratio to it.
Just a side note - 3:92 gears come as limited slip...3:55 gears do not.
In our climate, limited slip has some real benefits. With the advanced traction systems on the trucks (ESP/BAS) the limited slip will assist fuel mileage by applying drive to both rear wheels, where a non-limited slip will have the computer applying the brake to a spinning wheel to help transfer torque to the one with the traction. I don't believe that accelerating with any brake on is good for mileage.
brad
Interested in one of my mods?
Old 03-03-2011, 01:12 PM
Blue Streak Blue Streak is offline
Vehicle: 2011 Ram 1500 Sport 4x4
Rep:63
Blue Streak will become famous soon enough
Has anyone swaped to 3.92 on the Gen 4 4x4? Looking to do so with a possi or tru track.
Old 03-03-2011, 01:24 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
If you'll be runnin 35" or bigger tires get 4.56s
Old 03-03-2011, 01:34 PM
Rep:63
I have the 22" Vipers
Old 03-03-2011, 01:57 PM
Rep:2657
i am sure that chysler would gladly swap out your carrier assembly & your warranty would still be good
a good site to look at, that carries its own warranty, i believe they have a online calculator
i wouldn't be surprised if they also have the parts needed to make your 3:55 into a Limited Slip Differential
http://www.ringpinion.com/
i believe the 3:21 & 3:55 differential is standard equipment in the 2 wheel drive Rams, because the Federal Gov't have rules that say X amount of vehicles produced must meet certain fuel mileage standards
* side note *
a little known fact, is that new Rams sold for use in Mexico & are badged as 1500s, are in truth 2500s
they build most of the 2500 & most of the heavy duty Rams in Mexico & they don't want to import from the Warren Plant
Old 03-03-2011, 10:49 PM
CHVYKLR's Avatar
Rep:252
3.92s or 4.10s would work good.
GTYank - thanks for the post. pretty cool you can get a 2500 badged as a 1500. so do they get the 2500 tow rating?
Old 04-09-2011, 06:14 PM
James2345's Avatar
James2345 James2345 is offline
Vehicle: 2011 1500 ST Quad Cab
James2345 is on a distinguished road
In tow/haul I can shift 5 gears manually.
Old 04-09-2011, 09:24 PM
jc4041's Avatar
jc4041 jc4041 is offline
Vehicle: 2009 QC 4wd
Rep:146
jc4041 will become famous soon enoughjc4041 will become famous soon enough
June I'm having it done...along with my ARH L/T's....gonna run me $12-1400 (front and rear diffs) depending on which LSD I go with
Ram DSP, CAI, Cherry Bomb Extreme, AirLift 1000
'07 Dodge Charger SRT8 SuperBee #579-CAI, DSP, dual Cherry Bomb Extremes
'07 GCSRT Stock
