Old 08-19-2010, 01:53 PM
rancherman's Avatar
rancherman rancherman is offline
Vehicle: My DD is '97 Dodge Ram 1500
Rep:171
rancherman has a spectacular aura aboutrancherman has a spectacular aura about
Default driver side door mirror
My '97 with power adjust mirrors, needs it's driver side pivot tightened up. It's loose enough, that at 40 mph, it's usually flat against the door.
Am I correct in assuming that I need to take off the inside door panel to remove the mirror? I also assume there is a 'nut' to tighten a friction disk or something similar? If so, is there any hidden snaps or special removal techniques other than a 'typical' door panel removal?
LOL, I need all 'facilities' up to snuff for next months 'road trip'....
(you all are thinking...'Beverly Hillbilly')?? I won't have granny bungee strapped in the box though!
Old 08-19-2010, 07:56 PM
I'm not sure your gonna have any luck . I've tried before with no success on someone elses truck .
Old 08-19-2010, 08:03 PM
rancherman's Avatar
Rep:171
as in: no luck 'tightening' the loose post, or getting to it? I see LMC has replacement mirrors for under $100's.
Thanks tom.
Old 08-19-2010, 08:15 PM
No luck in tightening it up .
Old 08-19-2010, 09:30 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Tom,
Pop the panel on the inside the door where the mirror connects and unbolt it. See if you can find a way to do it. Worst that can happen is you waste an hour.
Brian:
Old 08-21-2010, 12:27 PM
mlrtym's Avatar
mlrtym mlrtym is offline
Vehicle: 1994/98 Ram 2500
Trim Level: SLT Laramie
Color: Flat Black
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
mlrtym is on a distinguished road
I have a set of Chrome mirrors that are tight. if you need one. optics are great, and the chrome is pitted slightly.
It is better to let one think you a fool, than to open your mouth and remove all doubt.
