Old 08-20-2010, 12:57 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Originally Posted by brvheart View Post
I called them yesterday - though they would not give me a price they said that it would be thousands of dollars and almost not doable - siting the fact that the transmission would not paired right and most likely would have to be changed. It is a 4x4 if that helps.
Remerson may come in and counter me on this, but I say BULLSH!T.
Call another dealer. All the Rams have the same transmission and no way would it cost thousands of dollars to fix.
Brian:
Old 08-20-2010, 11:18 PM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 2014 Ram 1500 Quad
Trim Level: Lone Star
Color: Blue Streak Pearl
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
Would cost 'thousands' at the stealer just to swap BOTH gearsets on a 4WD though,,,
The front is a PITA,,, OEM Gearsets can run (don't quote me) as much as 6-800 a set.
Transmission would not need to be swapped out, but would have to be flashed to make the speedo read right,,,
Old 08-23-2010, 04:31 PM
brvheart's Avatar
brvheart brvheart is offline
Vehicle: 2010 Ram 1500 Crew Cab
Color: Mineral Gray
Rep:34
brvheart is on a distinguished road
^ I just got a call from the dealer - around $5k to swap the gears from 3.55 to 3.92 - does that sound right?
Old 08-23-2010, 07:06 PM
dafoot dafoot is offline
Vehicle: 2011 Dodge Ram, 1500, Hemi
Rep:16
dafoot is on a distinguished road
I was considering doing the swap. But
DAFOOT
Old 08-23-2010, 07:34 PM
rinkerman rinkerman is offline
Vehicle: 2010 Crew Cab
rinkerman is on a distinguished road
Where do i find what gear ratio my truck has. Have looked all over. On my last ram the axle code was listed in the glovebox. Can't find it on my 2010
Old 08-23-2010, 07:40 PM
Color: RootBeer
Rep:1287
I just called a local 4x4 shop. Estimated cost would be $2400. At that price it would be worth it. Might want to check around and then go back to the dealer with the estimate in hand.
Brian:
Old 08-23-2010, 10:02 PM
Rep:135
Not to be negative, but the Dealer won't waste much if any of his time looking at a 3rd party estimate. Even if the 3rd party is using all OEM parts (doubtful) I just can't see a dealer doing any 'price matching' on this type of work,,,, Too much corporate red tape,,,
IMHO, dropping several grand on gearsets is a decision worth taking your time on,,,,
Going from 3.55 to 3.92 is really not that much of a change at all,,,, (about ~10%~, which,,, ball park figure,,, is only about ~200~ rpm @ 70 mph,,,,)
Please be very sure that you want only a 3.92 and nothing lower than that,,,, What would really suck would be if you dropped a good chunk of change on this and ended up with something that was pretty darn close to what you already had,,,,,
Old 08-24-2010, 12:36 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
You could always just step down a tire size. I got the 17's with the 265's, and it gives me a better ratio at the tires. I don't tow often, but enough that I decided not to get taller tires, just more aggressive.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 08-24-2010, 01:37 PM
MrPEZO's Avatar
MrPEZO MrPEZO is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x2
Trim Level: Crew Cab Outdoorsman
Rep:38
MrPEZO is on a distinguished road
There is a sticker on the rear axel, its listed there
2011 RAM Crew Cab Outdoorsman- Nav, Remote Start, 3.92 Gears, Alpine Stero, Mopar Bed Rug w/RAM Head, Mopar Black Side Steps, Tint, Weather Tech In Channel Vent Visors
2012 Durango RT
2006 Charger RT - Mopar Vent Visors, Daytona Blacked Out Grille, BT Catch Can, Air Hammer CAI-SOLD
Old 08-24-2010, 02:59 PM
Wildcat's Avatar
Rep:166
Mod please delete this post, it was a duplicate.
Last edited by Wildcat; 08-24-2010 at 03:05 PM. Reason: Stupid computer didn't show my earlier post.
