Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 08-19-2010, 10:39 PM
fletchnuts024 fletchnuts024 is offline
fletchnuts024 is on a distinguished road
Default modding questions
hey everyone im new to the cummins world and have some questions
i have always wanted a turbo diesel im gona be tradeing in my turbo subaru wrx i have modded that so im familer with [COLOR=blue !important][COLOR=blue !important]turbos[/COLOR][/COLOR] mods and tunes anyway...
im gona buy a 99 cummins and im not sure how easy it is to gain power i noticed its only 215 and 420 and most chips and power programers dont add as much power as the newer [COLOR=blue !important][COLOR=blue !important]cummins [COLOR=blue !important]engines[/COLOR][/COLOR][/COLOR] gain
so with a full exsaust intake and with and with out a tune what kind of power gains should i expect to see ??
also how do i tune it do most tuners come with pre loaded maps or dose it need to be tuned by someone that knows whats goin on with a dyno
also how easy is it to install injectors
im fairly good with machanics i enjoy doing my own work and maintance if i have the proper tools
any awnsers and insight about the 99 models and weather i should buy it and mod it or buy a new cummins for the extra [COLOR=blue !important][COLOR=blue !important]stock[/COLOR][/COLOR] hp
Thanks guys and or gals
Old 09-11-2012, 09:19 PM
cjdakota cjdakota is offline
Vehicle: 2000 dodge ram
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
cjdakota is on a distinguished road
If you combine a tuner like the Smarty, love mine, not only is it very easy to fine tune by loading tunes of from itself but fine tune beyond that, add injectors and a fueling box and you will have a pretty quick truck before even a turbo as long as you can get it to the ground. Built tranny and fueling mods are much needed before you can reach the potential of that power. There are you tube videos on injector installs. good luck
Old 09-11-2012, 09:48 PM
95dodgeV10's Avatar
95dodgeV10 95dodgeV10 is offline
Vehicle: 1995 dodge ram 2500
Trim Level: Laramie SLT
Rep:24
95dodgeV10 is on a distinguished road
my 01 has the same engine as the 99 and i have an old edge programmer and 100 horsepower injectors. it dynoed at 305 horsepower and 625 lb ft of torque at the rear wheels. injectors are fairly easy but the back ones suck to get a wrench on. so a bit of creativity may be needed.
