Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
MOPAR DECALS
Old 08-19-2010, 10:56 PM
chapala01 chapala01 is offline
chapala01 is on a distinguished road
Default 2008 Dodge Ram 1500 - battery
Hello -
I have had several problems with my truck battery.
. dead battery jumped started by Dodge
. two weeks later, dead battery...towed in to Dodge and battery replaced (2) months ago
. dead battery and jumped started
. towed in to Dodge and checked voltage regulator..no problems Later the same day my wife called the Dodge Rep and she explained in ALL TRUCKs you should start your vehicle at least once every (3) days and allow the engine to run for 15 minutes.
I then called Ford and Cherolet Truck dealers and was told there was no need to start their trucks every (3) days to keep their batteries up.
Has anyone had a similar experience with their Dodge Truck batteries<
Thanks,
Old 08-19-2010, 11:05 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Starting it every 3 days is hogwash. There's something draining that battery.
Brian:
Old 08-19-2010, 11:16 PM
Sounds like it could be a current draw , possible a bad battery (have seen it before even though it's new) , no or low amperage output from the alternator . Glad you joined us and welcome to the Z for Rams from Baltimore . If you could go to the top of the page to the User Cp and complete your profile that would be great . Helps us see what you have when your posting a question or comment . Do you have any pictures of your truck ? Have you done any mods or have plans for any ? Any of your friends have Rams ? Tell them about us . We would love to have them . You will find this site is full of a lot of talented people . So if theres any question that you need answered , just shoot away . Talk to ya soon . Tom
Old 08-19-2010, 11:17 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Hello and welcome to the site!
Old 08-19-2010, 11:49 PM
Rep:4232
Hello and welcome to the forum, glad to have you! Sorry to hear about your problem, must be one heck of an annoying inconvenience there, but I agree, something is not right there. I had a slow drain on the battery in my '81 D150 and granted that truck was much older, I never could find the cause, so the only thing I found to do if I wasn't going to drive it or start it up, was disconnect the battery. You might try that until you can figure out what's wrong, but good luck and be sure to keep us posted! Lots of great people and info here, so look forward to seeing you around the Z and I hope you enjoy the site!
Old 08-20-2010, 11:52 AM
Rep:1625
Welcome to the forum!
Old 08-20-2010, 12:16 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Welcome to the Z!!! Glad to have ya aboard!
I agree with the above posts as well. It's possible the battery is no good even though it's new, there could be something drawing current while you arent in the truck as well. Did you try putting it on a charger? The charging systems in our trucks are different then older vehicles, meaning they are good for "surface charging". By actually putting the battery on a good trickle, you will deduct some variables. I had a similar problem, and jumpstarting (which will get ya going) is not enough, the charging system will keep it stable, but not allow a full recharge. So, you end up jumpstarting constantly.
My advice.....either get the battery checked for bad cell(s), or put it on a charger and see what happens. If the battery checks out good, then you may have to chase down the draw. Autozone offers free battery and alternator testing, just FYI....
Old 10-06-2010, 01:06 AM
Hemi Rammer Hemi Rammer is offline
Vehicle: 2008 Dodge
Hemi Rammer is on a distinguished road
Default 08 1500 Ram battery
Hi there,
Any luck getting your truck fixed yet? I am having the same problem. I have a 08 Ram 1500 and it just started randomly going dead on me. I had the dealer check it out and they cannot find anything wrong with it. I started monitoring the voltage with my volt meter everyday before going to bed and when I saw the voltage going down I checked for a draw and found a 2.5 amp draw. I pulled fuses until it went away and it was fuse number 11 which basically controls every module inside the truck (int. lighting, keyless entry, radio, satellite, bluetooth). I have no idea how I am going to track down which one it is or if it is the wiring. It is still under warranty but I don't know if the dealer will take what I found serious and how long it would take for it to happen to them. I have had it go for weeks with no problem and then it will do it everyday. I make sure there is nothing on when I park the truck and pop the hood so I don't disturb anything when I check the battery hood lamp is also unplugged. I am starting to suspect the radio but would hate to replace it since it is the 6 disc MP3 with Nav. Not sure if this will help you at all but is what I found so far with mine. Good Luck.
Old 10-31-2015, 11:11 AM
Chilehead Chilehead is offline
Vehicle: 2007 Dodge Ram 2500 Mega-Cab
Chilehead is on a distinguished road
I have the exact same problem with my 07 Mega Cab. Trying to track it down right now. I've already removed the radio completely. The draw is still there.
Old 10-31-2015, 12:22 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 15 BigHorn Ecodiesel
Trim Level: Big Horn CC
Rep:239
namretsud has a spectacular aura aboutnamretsud has a spectacular aura aboutnamretsud has a spectacular aura about
Anyone with a 3rd gen truck should have by now replaced their battery as the average life expectancy (from a battery rep) is 3-5 years. Any more then that you are on borrowed time. With the truck off you should see at least 12.4 vdc. Running you should have 13.5-13.7. A good load test on a charged battery will point out any weaknesses in the battery. I had a 1 year old battery go bad in my car and when load tested it showed up as a bad cell.
