Old 08-19-2010, 11:12 PM
Black05's Avatar
Black05 Black05 is offline
Vehicle: 2005 Ram
Trim Level: 1500 4x4 SLT
Rep:63
Black05 will become famous soon enough
Default Rear Underseat Box Progress
Just a thread to show the progress on my sub boxes. First off this is my first fiberglass project, so don't flame too much lol. I traded a buddy of mine a Skunk2 muffler for 2 10" JL subs and I wanted them in my truck so I thought I would try my hand at DIY rear underseat boxes. I'll also do a "write-up" of the steps I took.
Test fitting, excuse the dirty interior
Passenger Side
Driver Side
So much for storage space lol.
Ok on to my process, sorry no detailed pics of each step:
Step 1: Get materials and make sure you have the tools too lol.
Step 2: Mask your workspace using blue painters tape. I used a crosshatching method, (one layer longways the next went perpendicular). Just make sure your work area is covered to include extra as the resin is messy and not very forgiving to your interior.
Step 3: Take a package of fiberglass mat and tear it into small manageable pieces (about 8"-12" shapes). I mixed some resin and hardener and "painted" it on my tape.
Step 4: Take your small mat pieces and lay them on your tape then mix up about 4oz of resin and the appropriate amount of catalyst/hardener.
Step 5: Apply your resin mix to the fiberglass using a cheap paint brush. The best technique to use is stippling. Fiberglass should go from white to transparent.
Step 6: Next go right into your next layer and repeat for as many layers as you choose (I ended up with 8 layers on my first box and 6 on my second)
Step 7: Relax for a few hours, everything needs to harden. Plus you may need to stretch from being hunched over while layering.
Step 8: Once you are sure your molds are 100% dry pop them out, don't be scared cuz if you did it right it will be strong.
Step 9: Next make your sub rings I did a single ring, looking back I should have done a double so that I could do a flush mount. Oh well live and learn, they'll still get the job done I hope lol.
Step 10: Mount your sub rings using dowels. I struggled a bit here for some reason or another. Once they were "in place" I used fiberglass to secure them, this worked extremely well as once dry the rings were very sturdy.
Step 11: Making your box a box, trim up the edges with a dremel or jigsaw and cut your holes for the box terminals for your wires.
Step 12: Wrap the top and sides of your boxes with some stretchy cloth (fleece) I used a poly-cotton blend from Walmart (I think like 65/35), use 3M spray adhesive and pull the fleece tight.
Step 13: Once dried mix up some more resin and apply directly on the fleece, then let that dry completely
Step 14: Looking more like a usable item, now that your fleece is semi hard from the resin add layers of fiberglass over the fleece, again 5-7.
Step 15: Another trimming session.
Step 16: Finish your box with cloth, vinyl, or paint.
Step 17: Mount your subs and wire them up.
NOTE: Pics show the floor extenders still on, they will have to be removed once completed
05 1500 In Progress: Saving for more mods!
Old 08-19-2010, 11:26 PM
ram71351's Avatar
ram71351 ram71351 is offline
Vehicle: 2014 Dodge Ram Laramie
Color: Black Gold Pearl
Rep:45
ram71351 is on a distinguished road
Seems like a lot of work, why not just buy? I guess there's no better feeling than doing it yourself. Very Nice Work !!!!!
Old 08-19-2010, 11:30 PM
Black05's Avatar
Vehicle: 2005 Ram
Rep:63
It is, but for the price and the feeling that I did it like you said, thats all I need! Thanks
Old 08-19-2010, 11:39 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Looks great and looking forward to the continued progress reports.
Brian:
Old 08-20-2010, 03:38 AM
Rep:4085
Looking good so far, thanks for the write up and pics and please do, keep us posted!
Old 08-20-2010, 04:39 AM
I push the skinny pedal
Rep:3298
I agree, I like the do-it-yourself stuff, I'm currently 'glassing my front door panels and have followed a very similar process, only difference is, I lay 2 layers then let it cure, sand it down, then add 2 more layers of 'glass. sand, then spread kitty-hair bondo, cure, sand, then body filler.
Kurtis
Old 08-20-2010, 05:42 AM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
I hear fiberglass work is like an art, so for any of you who can do fiberglass work - my hat is off to you. Good stuff, can't wait to see more.
Old 08-20-2010, 07:43 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Looking good!
Old 08-20-2010, 11:12 AM
Black05's Avatar
Vehicle: 2005 Ram
Rep:63
CdnoilRAM- Yeah that sounds more proper, but I figured I wouldn't see mint except for the top lol. I'd like to see some pics if you have them.
Thanks for the complements, its very encouraging. I just need to get some freetime so that I can finish them up.
Old 08-20-2010, 11:39 AM
Rep:1625
Looking good!
