Old 08-02-2011, 07:00 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
that pipe insulation looks like a great idea!!!! I might try the tube with a used Volant I am waiting for!
Old 08-02-2011, 07:13 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
Ordered the KN 1026 Cone Filter from Amazon w/ free shipping which should arrive by the 5th. Not my first choice but its close for off the shelf.
6" inlet flange
7.5" bottom od
7" top od
11" height
Old 08-02-2011, 07:44 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
The Volant has lower port built into their sealed box already just begging for this mod
and I hear production of an optional lower air scoop will be out in November for the 4G Ram's.
They do it for several other makes/models already http://www.volant.com/scoops.asp
this is what the Chevy Silverado HD unit looks like:
Old 08-03-2011, 02:45 AM
Rep:554
Right after I shot this pic I realized just how nasty the dirt and bugs collecting in the fins was ,
I dont normally see my filter from this angle so I thought it still looked okay from the front...Ooops!
Guess I'm due for my first cleaning/re-charge after almost a year
Soaked it with degreaser and let it sit for 10 minutes
Then rinsed from the inside out with a light low pressure shower nozzle on the garden hose and let it dry for 4 hours next to a fan.
Then a light spray oil and let it wick in for 20 minutes...check for white spots and give it another light dusting of oil and let it dry overnight before re-installing the morning.
Bet I'll be even Faster getting to work tomorrow now!
Clean and Dry waiting for some fresh Red K&N Oil.
I use the K&N recharge kit because it was only $12 locally vs $20+ for the Airaid recharge kit.
This shot gives a good idea of the filter size compared to a coke can...with some fresh Red Oil!
Old 08-03-2011, 10:11 AM
ICEMAN99TURBO's Avatar
ICEMAN99TURBO ICEMAN99TURBO is offline
Vehicle: 08 Ram
Trim Level: 1500 Big Horn
Color: Electric Blue Pearl
Rep:119
ICEMAN99TURBO will become famous soon enoughICEMAN99TURBO will become famous soon enough
Send a message via AIM to ICEMAN99TURBO Send a message via Yahoo to ICEMAN99TURBO
Lowes Hardware 3.5" Flex Tube (I bought two and a coupler, but because they can extend and bend from 9" up to 21" only one was required)
intake air is now "Rammed" in and up toward the stock fender port from the FRONT where air pressure is highest (at speed) instead of the motor having to suck air from below.
View from below, lower left is the input side, lower right is the fog light housing, up the fender is the blue bungee cord holding the top of the tube in place.
(There's a second bungee holding the lower front of the tube near the bumper)
Testing has been limited to street only so far and I'm melting my poor Terra Grapplers! I can tell by my butt dyno it's working well.
Track testing to follow, and I still have to get a base line Dyno run (slated for August 12th) before my Edge Torque Converter and JBA Headers get installed then my custom CMR Dyno Tuning session.
Great idea with the tubes bud, but will all the ribs you are loosing a lot of air flow. If I was you, I would use them as a template and take them to your local fabricator and have him make you a set of Alum tubes with the bend you need. You will notice the difference.
Don't park in the ditch, that's not where you park, you park in a parking lot! .... Stupid!
Old 08-03-2011, 10:16 AM
Rep:554
a few more pic's from this morning after re-installing
Oiled, installed and ready to roll again...
Now that everything is flowing free clean clear and cold,
my early morning commute to the office freaked me out!
Super Fast when the cool morning air was only 12ºC (~50ºF)
916Timmy's Avatar
Rep:1443
That Airaid filter is a beast!
Old 08-03-2011, 11:24 AM
Rep:554
Already have my Guy lined up LOL!
...a Neighbor a few homes down from me builds custom turbo setups in his garage, mostly for 350z/370z cars...but he want's to do a Turbo setup on my Ram next...
We met at the track last year when he recognized my truck, when he told me where he lived I recognized his name and it turns out I designed his home...small world
Damn fine TIG Welder/Fabricator,
Since you're a Turbo guy, you should like this ...
a few pics of his Z and a link to his build here: http://my350z.com/forum/forced-induc...rbo-build.html
Old 08-03-2011, 06:59 PM
Focalforge Focalforge is offline
Vehicle: 2011 Ram 1500 Sport Crew white
Rep:27
Focalforge is on a distinguished road
I just ordered my Airaid (http://www.airaid.com/ProductDetail....ductID=301-237) from amazon for $371.90 with free shipping to my home here in AK. i'm probably going to use your idea, BM, to use pipe insulation to make a better seal on the hood. I'm going to need to look at the setup in person, once installed and might pick up the diy kit too, so I can plumb colder air into the box. I'll post pics of what I end up doing. I'll proably have to forge up some special brackets to hold everthing still though.
cheers
Old 08-04-2011, 02:39 AM
Vehicle: 08 Ram
Rep:119
Very cool, hope he builds the Zs up well, hear they don't take too to boost. Will be an interesting project have to hit me up with the link so I can check it out as it unfolds.
