Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 08-20-2010, 06:52 AM
BronteRider's Avatar
BronteRider BronteRider is offline
Vehicle: 1997 Ram 1500
Trim Level: Laramie SLT
BronteRider is on a distinguished road
Default A/C affects idle
When I turn on the A/C, the idle speed lowers, and if i rev it up rpms are just under the first line, if it doesn't die. Has anyone else had this problem? If so what was the solution?
Old 08-20-2010, 06:53 AM
I mean when I rev it up and it idles back down, just to be clear.
Old 08-20-2010, 08:22 AM
Rep:1909
Clean the throttle body lately?
Old 08-20-2010, 11:07 AM
Black05's Avatar
Black05 Black05 is offline
Vehicle: 2005 Ram
Trim Level: 1500 4x4 SLT
Rep:63
Black05 will become famous soon enough
Shouldn't be causing your truck to die, but remember your a/c compressor is connected to your drivebelts so when it's running it is pulling on your motor. Parasitic drain just like on a s/c just no extra power.
05 1500 In Progress: Saving for more mods!
Old 08-20-2010, 11:38 AM
When the A/C compressor engages, it adds parasitic drag and slows the engine idle. It should not die, though.
What is your idle RPM with it off and with it on?
Old 08-20-2010, 04:12 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Don't run the A/C on max when idling.
Brian:
Old 08-24-2010, 10:11 PM
The RPM's are the same with the a/c on and off, right under 750rpm's, but it is usually on max so that could be it. and no, i haven't cleanedthe tb.
Old 08-24-2010, 10:18 PM
That sounds good to me .
