Exhaust Thoughts... - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-20-2010, 06:57 AM
ShotGunWillie ShotGunWillie is offline
Vehicle: 2009 Dodge Ram 1500 Crew
Trim Level: 4x4 ST
Rep:20
ShotGunWillie is on a distinguished road
Default Exhaust Thoughts...
Okay, CAI is coming shortly, next move is exhaust. This is what I was thinking about doing, not sure if it makes sense, so work with me please.
I am not looking for loud, just throaty, deep, not much louder than stock at idle. So I was thinking of just keeping my current set up and have just the muffler cut off and either a magnaflow or flowmaster installed in its place. Single in and single out. Will that be enough of a modification or do I need to replace the tail pipe (which its my understanding that the resonator will then be removed which will make it louder). What is the diameter of the stock pipe? Is replacing just the muffler worth it?
Old 08-20-2010, 11:41 AM
Rep:1625
I have a single in/single out Magnaflow muffler on mine and I'm very happy with it. The resonators help with the drone that bothers you when MDS kicks in.
Old 08-20-2010, 12:36 PM
Trim Level: 4x4 ST
Rep:20
Did you replace the tail pipe, which magnaflow muffler?
Old 08-20-2010, 01:04 PM
I'd go with the muffler replacement. You won't need to replace your tailpipe unless you decide to go with a single in/dual out setup like I did.
To decide what muffler to go with, crawl under the truck and see what the stock inlet/outlet pipe configuration is, i.e. center/center (through the center of the muffler at both ends), center/offset (center inlet, offset outlet), offset/offset (offset in, offset out) then measure the OD of your pipe (it's probably 2.5" - 2.75" but it may be 3.0").
Then go to Magnaflow's website and do a little searching. It's an easy site to work with.
Good luck!
Old 08-20-2010, 01:16 PM
one2ram's Avatar
one2ram one2ram is offline
Vehicle: 2010
one2ram is on a distinguished road
also its 3'' pipe, if you want to help with with flow get a different Y-pipe
Old 08-20-2010, 02:54 PM
Good info ^^^^ and I agree. If you aren't going to a true dual system, get a good flowing Y pipe. That piece seems to be the most restrictive part of the exhaust.
Old 08-21-2010, 12:42 AM
Blackzilla's Avatar
Vehicle: 2009 Reg Cab S/B 4X4
Trim Level: Sport/SLT
Color: Black Pearl
Rep:199
replace muffler your choice/ y pipe.
Old 08-21-2010, 12:51 AM
HeadHunter HeadHunter is offline
Rep:34
HeadHunter is on a distinguished road
check out Borla. they have some throaty mufflers.
Old 08-22-2010, 08:52 AM
Medic1's Avatar
Medic1 Medic1 is offline
Vehicle: 2009 Dodge Ram QC 4X4
Medic1 is on a distinguished road
Are there different configurations? I thought all the '09s were 3" pipe center/offset.
Old 08-22-2010, 10:19 PM
Mattones's Avatar
Mattones Mattones is offline
Vehicle: 2009 Dodge Ram 1500 SLT Quad
Rep:164
Mattones has a spectacular aura aboutMattones has a spectacular aura about
FLowmaster is you want throaty but keep the res if you dont want roaring like a lion. hehe
2009 Dodge Ram 1500 4x4 5.7 Hemi Quad Cab
Cat Back Magnaflow Exhaust stainless, Tinted Front Windows, Painted Engine Cover, Red Calipers, LED Reverse Lights, Lightbar and 4 Hella 500
