Old 08-20-2010, 05:45 PM
Carvermitch's Avatar
Carvermitch Carvermitch is offline
Vehicle: 2002 Dodge Ram 1500 quad
Color: Garnet Red metelic
Rep:12
Carvermitch is on a distinguished road
Default c code 00 00
Hi All
I have the engine light on all the time and on checking the code it comes up only one code 00 00.
No one can tell me what it is.
Everything function perfect and starts perfect.
I have a basic 4.7 2002 1500 with no cruise control or any other extras, just plain old Dodge. It runs well and gives good economy just this light on.
Any suggestions please.
thanks
Paul
Old 08-20-2010, 06:01 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Best I can find is "end of test, no errors found" or something like that. As for the check engine light itself, when was the last time you had it serviced? Sounds like there is a reset needing to be done.
Brian:
Old 08-20-2010, 07:07 PM
How did you acquire the codes ?
Old 08-20-2010, 07:32 PM
Rep:12
I turned the key on an off quickly with the odometer button pushed in and the dash panel goes through a self test and shows the codes where the mileage reads.
It comes up c code 00-00.
If I disconnect the battery it goes out for a day or so then comes on again.
Old 08-20-2010, 07:39 PM
Color: RootBeer
Rep:1287
Found one that says its Vehicle speed information circuit. This was for a 2004 Ram.
Brian:
Old 08-20-2010, 07:55 PM
Rep:12
Hey thanks guys, I appreciate the help
The speedo works perfect and I do not have cruise control
Old 08-21-2010, 12:04 AM
RidgeRock's Avatar
RidgeRock RidgeRock is offline
Vehicle: 2002 Dodge Ram Quad Cab 4WD
Color: Metallic Graphite
RidgeRock is on a distinguished road
Check your gas cap. Click it 4-5 times when tightening it.
Old 08-21-2010, 11:25 AM
Rep:1909
You need to pull the codes with an OBDII scanner that can pull manufacturer specific codes as well as generic codes.
Old 01-29-2013, 03:50 PM
jlmursch jlmursch is offline
Vehicle: 2003 Dodge Ram 1500
jlmursch is on a distinguished road
Did you ever find out what the problem was. I just got the same code.
Old 02-10-2013, 07:56 PM
Tentman's Avatar
Tentman Tentman is offline
Vehicle: 2003 Ram 1500 QC 4.7 SLT
Color: Atlantic Blue
Rep:26
Tentman is on a distinguished road
Try doing the key trick without the odometer button pushed in, Just On - Off, On - Off , On - Off , On and see what it displays,
Thats how mine works to show codes.
