Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Dodge Ram Decals
Old 08-20-2010, 11:28 PM
srtsir's Avatar
srtsir srtsir is offline
Vehicle: 2004 Dodge Ram
Rep:198
srtsir has a spectacular aura aboutsrtsir has a spectacular aura about
Default Hey Guys I need some help....
My brother took off of the light today and didnt notice anything until about 200 yards down the road...The car lost power and shut off kinda like alternator when it goes bad after we went home got some jumper cables the car started fine but there was a ticking noise coming from underneath where the tranny and starter and bell housing is...It does it even when in park or gear...And as you press gas it speeds up....ANY IDEAS?????
5.7 HEMI, DIABLO, K&N INTAKE, MBRP CATBACK, 4.56 MOTIVE, DMH E-CUTOUTS, 22X10 SRT-10 RIMS (BLACK), 315/45/22 COOPER ZEON XST'S, 2/4.5 MCGAUGHYS DROP KIT, 6K HID'S FOGS & HEADS, RECON L.E.D TAILGATE STRIP, EFX ROLLPAN, TRUXEDO LO-PRO, HORNBLASTERS 156DB TRAIN HORN, HONEYCOMB GRILLE....
Old 08-20-2010, 11:38 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Try it in the dark and see if you any sparks jumping around. Sounds kind of like a plug wire has burned through its insulation and is arcing.
Brian:
Old 08-21-2010, 12:34 AM
srtsir's Avatar
Rep:198
there is no noise coming from the engine bay ... it sounds like its coming from where the starter and trany is....
Old 08-23-2010, 05:34 AM
srtsir's Avatar
Rep:198
Default Please Help
http://www.ramforumz.com/showthread.php?t=59706
Anyone knows what this could be....Also when he guned it he went over a bump and thats when his car shut off and lost power and came back with ticking noise....Could it be that his torque converter shit to bed....
Old 08-23-2010, 08:41 AM
srtsir's Avatar
Rep:198
Could it be spun rod bearing....The truck has 68K...The ticking gets faster with rpm's higher even in park position
Old 08-23-2010, 08:36 PM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 1492 Santa Maria
Color: Hot pink
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
How big a bump? How fast??? Have you looked under the truck?
Old 08-24-2010, 03:42 AM
srtsir's Avatar
Rep:198
Not that big of a bump...Well today we checked for metal shavings in his oil pan but everything is clean his oil pressure is normal.....It sound like the noise is coming from bellhousing....
Old 08-24-2010, 08:06 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Torque converter bolt loose maybe?
Old 08-24-2010, 08:13 AM
Can you post a audio clip for us to hear ?
Old 08-25-2010, 06:15 AM
05 D Rod 05 D Rod is offline
Vehicle: 05 big horn qc
05 D Rod is on a distinguished road
I bet it is a rod hitting the oil pan. Happened to me before so dont rev the motor any more unless you want to blow the rod thru the pan!!!!!
