Old 08-21-2010, 10:38 AM
1RamRunner 1RamRunner is offline
Rep:19
1RamRunner is on a distinguished road
Default What radio do I want?
I have the RES radio in my '09 original from the factory. I want to upgrade to a radio that has U-Connect, 6 CD Changer, SAT, and capability to add Back-up Camera. Navigation isn't necessary, but is a possibility. What Factory and Aftermarket options do I have?
Thanks,
Jim
Old 08-21-2010, 10:43 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
The RER mygig.....
Old 08-21-2010, 11:47 AM
sowardcustoms's Avatar
sowardcustoms sowardcustoms is offline
Vehicle: 2013 Ram R/T
Trim Level: R/T
Color: Gray
Rep:145
sowardcustoms will become famous soon enoughsowardcustoms will become famous soon enough
Thanks,
Jim
REN if you don't have to have Nav. It will hold a whole lot more than a 6 cd changer would so you dont have to worry about that but you will have to buy the uconnect kit with the RER the uconnect module is built in the radio so you just add a microphone with both units you can add a backup camera...
Old 08-22-2010, 09:35 PM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:71
topgun will become famous soon enough
RBZ is the newer version of the REN. I'd get that instead if going that route as it addresses a few issues such as the REN blowing up if you don't pull the fuse before disconnecting the battery. Both come with and without SAT so be sure of what you are buying.
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Cooper AT3 285/70/R17's, S&B Intake, Moroso Catch Can
Old 08-23-2010, 12:50 PM
Trim Level: R/T
Color: Gray
Rep:145
Well then if we are talking new go all out and get the new RHB low cost nav unit...RHB_Radio_Details.pdf
Old 08-26-2010, 09:17 AM
Rep:19
Will the RHB work in my '09 Ram with factory wiring?
Thanks,
Jim
Old 08-26-2010, 10:52 AM
Trim Level: R/T
Color: Gray
Rep:145
Thanks,
Jim
It should but I don't have the specs on it yet to my knowledge they haven't been released yet...look for it in the fall...
