Old 08-22-2010, 01:26 PM
carrayz's Avatar
carrayz carrayz is offline
Vehicle: 1999 dodge ram 1500 ext cab sb
Trim Level: laramie slt
Color: silver
Rep:21
carrayz is on a distinguished road
Unhappy no low range
went to engage low range and it will not go in.4 high works fine.just serviced it not to long ago and every thing looked good no metal shavings in fluid.plus now my 4x4 light stays on somtimes. i used dextron 3 in the case is that right...
Old 08-22-2010, 01:35 PM
RamTech RamTech is online now
Rep:1885
Have you checked the shift lever and/or adjustment? The original fluid in your case would have been Mopar Dexron II. The current Mopar replacement is ATF+4 which is synthetic. As long as your current fluid is backward compatible, you should be ok.
Old 08-22-2010, 03:36 PM
As Randy says, I'd check the lever/linkage to make sure it's traveling all the way to 4WD Lo position.
Old 08-23-2010, 12:25 PM
carrayz's Avatar
Color: silver
Rep:21
ya it was not traveling far enuff. made adjustments works great.changed to ATF+4 feel lot better bout it now.thank you gentlemen..
Old 08-23-2010, 01:04 PM
Rep:1885
Glad to help.
Old 08-24-2010, 09:47 PM
Mtx's Avatar
Mtx Mtx is offline
Vehicle: 97 Dodge 2500
Trim Level: 2500 4x4
Color: hunter green
Rep:16
Mtx is on a distinguished road
another problem solved. good stuff
