rke/fob memory help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Electrical
Old 08-22-2010, 04:35 PM
RandyS RandyS is offline
RandyS is on a distinguished road
Default rke/fob memory help
user guide and cd owner's manual seem to say something diff. one says turn to off then press lock, other says take key out and hit lock to memorize seat memory......wife is smaller than me and when I get in truck it slides me to her last memory (#2) and squishes me..I can stop it by hitting one....but thought salesman told me that each key fob can memorize for 1 or 2 setting......truck is only a day old but have fiddled with this and cannot get it....anyone have any luck with this..if so...a laman walkthrough of step by step would be really appreciated!
Old 08-23-2010, 09:00 PM
Rep:1625
Old 08-24-2010, 11:13 AM
sowardcustoms's Avatar
sowardcustoms sowardcustoms is offline
Vehicle: 2013 Ram R/T
Trim Level: R/T
Color: Gray
Rep:145
sowardcustoms will become famous soon enoughsowardcustoms will become famous soon enough
MEMORY SEAT SYSTEM
An electronic memory seat system is available on certain models. The memory system is able to store and recall all driver side power seat positions, and the drivers side view mirror positions. The system can be set for two different drivers. On vehicles with a factory installed radio connected to the Controller Area Network (CAN) data bus network, the memory system is also able to store and recall up to twenty radio station presets (ten AM and ten FM), also for two drivers. The memory system also will store and recall the last station listened to for each driver, even if it is not one of the twenty preset stations.
The memory system will automatically recall all of these settings when a button of the memory switch is depressed, or when the doors are unlocked using the FOBIK transmitter (if enabled). If the vehicle has more than two drivers the FOBIK transmitter recall of memory features can be disabled. This is a customer programmable feature of the EVIC.
The memory system also has a easy exit feature that will move the driver seat rearward 55 millimeters or to the end of its travel, whichever occurs first, when the key is removed from the ignition switch lock cylinder. This is a customer programmable feature of the overhead console.
The memory system includes the following components:
Memory Selector Switch - located in the driver seat trim panel.
Driver Door Module (DMM) - located in the driver door, behind the trim panel.
Passenger Door Module (PDM) - located in the passenger door, behind the trim panel.
Hall Effect Sensors - Drivers Mirror - The hall effect sensor is permanently installed on the drivers side view mirror motor. This hall effect sensor is used to provide a reference signal to the memory heated seat mirror module, letting the module know the exact position of the mirror.
Wireless Integration Node (WIN) - located at ignition key cylinder.
FOBIK Transmitter - located with ignition key.
Memory Seat Module (MSM) - located underneath the driver seat, also controls the Adjustable Pedals and Mirrors.
Hall Effect Sensors - Seat Track - These hall effect sensors are permanently installed in each of the power seat track motors. They are used to provide a reference signal to the memory heated seat mirror module, letting the module know the exact position of the seat cushion and recliner.
Radio - located in the instrument panel center stack.
Automatic Temperature Control (ATC) - located in the instrument panel center stack.
Old 08-24-2010, 11:14 AM
Trim Level: R/T
Color: Gray
Rep:145
MEMORY SEAT SYSTEM
The Memory Seat Module (MSM) receives battery current through a 50 amp fuse in the Totally Integrated Power Module (TIPM) so that the power seats remain operational, regardless of the ignition switch position. When the driver memory seat switch control knob is actuated, a resistance signal is sent to the MSM via the Controller Area Network (CAN) bus circuit. The MSM is responsible for the 12v battery feed and ground path to the power seat adjuster motor. The adjuster motor operates to move the power seat adjuster mechanism through its drive unit in the selected direction until the switch is released, or until the travel limit of the adjuster is reached.
The MSM receives memory set/position switch input through the CAN bus circuit. The MSM also receives hard wired input from the hall effect sensors, mounted on each of the driver power seat adjuster motors and the driver side view mirror motor. The programmed software in the module allows it to know where the seat/mirror is located in its designed travel by a pulse count generated from the hall effect sensors. This way, when the memory switch is depressed the module will power the seat adjuster/mirror motors until the correct preset location is achieved. The module will prevent the seat memory recall function from being initiated, if the transmission gear selector lever is not in the Park position, or if the vehicle is moving. These inputs are monitored over the Controller Area Network (CAN) bus circuit by the MSM.
A memory setting is saved by pressing the “set” button, then pressing either the memory “1” or “2” button within 5 seconds of pressing the “set” button.
A memory setting is recalled by pressing either the memory “1” or “2” button, or by pressing the unlock button on a “linked” FOBIK.
For driver safety, memorized settings can not be recalled if the transmission is in a position other than Park or the seat belt is latched.
