Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8
Place your Ad Here!
Old 08-23-2010, 10:11 PM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
Hey guys, I am a plumber by trade. PVC in either 3 or 4 inch diameter would work theoretically speaking but watch the different weights on the pipes. We use a 4 inch thin wall for sewer that would be light enough and seal well with a good glue. The schedule 40 and heaver pipe rated for pressure would be really heavy under the hood.
Just a thought as I like the double air intake idea.
Old 08-23-2010, 10:27 PM
Good info . Thanks .
Old 08-24-2010, 12:51 AM
A buddy of mine fabbed one up for his Dodge Magnum...came out pretty good.
I'm sure this is doable!
Old 08-24-2010, 01:51 AM
Ryank's Avatar
Ryank Ryank is offline
Vehicle: 2009 Dodge Ram
Rep:199
Thanks guys, once i get back in school and have use of the shop, i'll try and plan something up, the biggest problem is finding or making a dual intake hat.
Carven exhaust, K&N CAI, Leveled with wheels and tires, Sundown & Skar audio.
Old 08-29-2010, 02:52 PM
ICEMAN99TURBO's Avatar
ICEMAN99TURBO ICEMAN99TURBO is offline
Vehicle: 08 Ram
Trim Level: 1500 Big Horn
Color: Electric Blue Pearl
Rep:119
ICEMAN99TURBO will become famous soon enoughICEMAN99TURBO will become famous soon enough
Send a message via AIM to ICEMAN99TURBO Send a message via Yahoo to ICEMAN99TURBO
Originally Posted by bones64 View Post
I used platic pipe for my CAI.......Workes great. Cheap as well. I agree with Randy regarding water.Two pipes from your fog lights in a decent rain or water could make it to your throttle body. That would be a disaster.
Schedule 30 or 40? PVC?
Don't park in the ditch, that's not where you park, you park in a parking lot! .... Stupid!
Old 09-04-2010, 06:16 PM
Kilkenny's Avatar
Kilkenny Kilkenny is offline
Vehicle: 1996 Ram 1500
Rep:40
Kilkenny is on a distinguished road
I would worry about water with the pipes down near the fog lamps, but I think two pipes are much better than one there. If you get some water near there with two, the engine is going to suck in air from the clear one instead of the wet one. If you put one straw in water and one outside the glass and suck through both, you won't get any water because it is easier to pull in more air from the other straw.
The problem would be when both get soaked and both are sucking in water, but that is the risk you take with putting the pipes that low. Hopefully having two would eliminate most of the problems.
"Upon further review, we have determined that the shoestring is not a machine gun..."---Bureau of Alcohol Tobacco Firearms and Explosives, June 25, 2007
Old 09-09-2010, 09:56 PM
j0k3r's Avatar
j0k3r j0k3r is offline
Vehicle: 1997 Dodge Ram 1500
Trim Level: sport 4x4
j0k3r is on a distinguished road
Default might werk but what about fuel mileage???
just was thinking of this same idea a couple days ago. talking to my buddy he brought up the point that while increasing hp it would decrease mpg dramatically. suggested that I use a 3 or 4 inch pipe instead of dual CAI, but I still like the idea of the dual intake. I am gonna try an off shoot idea using a single intake pipe but having a Y pipe on the tip of the filter and a piece of flex tube on both sides of the radiator. I should have it mostly done saturday without the heat shield.
Old 09-12-2010, 04:57 AM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
Question
So I just finished my diy "Ram Air" CAI. Using stock air box I enlarged the exsisting inlet hole to acomodate a 4" 45 pvc elbow angled towards a clear tight path inbetween the radiator n inner wheel well. I coupled it to a schedule 40 "Thicker n Heavier" PVC pipe that ended bout 2" above fog light were it coupled to a 6" to 4" cone shape aluminum hvac style reducer / coupler. FINALLY a 90 HVAC scoop That had a 6" Inlet on one end and 12"L 10"W 2.5"H rectangle on other end of the " L " shape scoop. Top of scoop was flush w/ bottom of bumper. I had to cut away a 12" long piece of plastic trim that clips on underneath bumper so air could pass directly into scoop n attached a black 13L 2.5H metal screen on my black trim for a less noticeable gapping rectangular air scoop that looks OEM!!! hehehe. PICS WILL FOLLOW.
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
