Old 08-23-2010, 04:38 PM
TexasAggie97's Avatar
TexasAggie97 TexasAggie97 is offline
Vehicle: 2002 Dodge Ram 1500
Trim Level: SLT Sport
Color: Graphite Metallic (Dark Grey)
TexasAggie97 is on a distinguished road
Unhappy Power Window works, power door lock and speaker does not?
My rear driver side power door lock and speaker stopped working. My window still powers up and down (thank goodness). I tested the speaker and the actual speaker works, when hooked up to the rear passenger side door.
Are the speaker wires connected through the power door lock mechanism so that when the mechanism fails, so does the speaker? Does anyone have a video or photos of how to uninstall the door lock mechanism? If I have to order it, what part is it actually called, mechanism seems very general.
Is this a difficult fix? I am somewhat mechanically inclined if I have the right tools (took me bit to find the T30 size Torx screw driver so I could remove the handle).
Old 08-23-2010, 04:53 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
You can also us a 10mm socket for the door handle...
Old 08-23-2010, 09:32 PM
I push the skinny pedal
Rep:3277
You might check to make sure the harness that runs between the door and body is properly connected. You need to pinch both the front and back to remove it, check for corrosion, clean as required, add some dielectic grease for better connections, then plug it back in. Cheapes thing to try.
Kurtis
Old 08-23-2010, 10:02 PM
anyone know of a good visual site that shows, in-depth, how to properly remove the wiring and window/door lock mechanism? I can easily remove the speakers but it seems the rest is bolted onto the door frame. I don't want to remove the wrong thing or order the wrong part!
Old 08-23-2010, 11:03 PM
Rep:3277
I'd get a hold of Remerson228, he might be able to get you something, he's a chrysler tech
Kurtis
Old 10-11-2010, 09:50 PM
luvmyhemi65 luvmyhemi65 is offline
Vehicle: 2004 Ram Quad Cab
luvmyhemi65 is on a distinguished road
Default door problems
I have an '04 ram quad cab which had the same problem. Speaker and power lock stopped working on my rt rear door last summer. I found that the wires between the door pillar and the door were cut clean through. You have to remove the rubber boot that protects the wire harness. This is an easy fix, just unplug the harness from the door pillar, pull back the boot and splice the wires.
I was surprised to see that someone else had the exact same problem as I did. I wonder if someone on the assembly line had a bad day?????
Good Luck
SM
Old 10-22-2010, 11:53 PM
Mikel Mikel is offline
Vehicle: 2006 Dodge Ram Quad Cab
Trim Level: SLT Lone Star
Mikel is on a distinguished road
also you can check the voltage from the back side of the connector and the front side of the connector to make sure that you are getting a signal and they are the same... it may appear to be connected well but may be loose or corroded inside of the connector
[IMG]http://mikel.com/images/Image2.jpg[/IMG]
Old 10-23-2010, 12:31 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Good Luck
SM
This is actually a common problem.....not specific to Dodge. It looks like the wires were cut....but they weren't....just broke from flexing in the same place, so we can feel confident that the assembly line workers didn't cause this.
As indicated in the post I quoted, the fix is pretty easy.
brad
Interested in one of my mods?
Old 11-18-2010, 09:14 PM
SoArkSi SoArkSi is offline
Rep:39
SoArkSi is on a distinguished road
I have an 05 quad cab with the same problem.......driverside rear door. I Have spliced the wires twice now, does anyone know where I can get a complete door harness??? I looked and where it connects at the door pillar, it goes into the door and splits to all the different areas. Thanks for any help.
Old 01-17-2011, 12:17 AM
nhynne's Avatar
nhynne nhynne is offline
Vehicle: 2003 Dodge Ram 1500 4.7
Trim Level: SLT Quad Cab
Color: Charcoal Grey
nhynne is on a distinguished road
Good Luck
SM
Thanks for the info had the same problem and is now fixed!
power door locks, speakers
