Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 08-23-2010, 09:57 PM
funflag funflag is offline
Engine: 1993-1993 360ci (5.9L) Magnum V8 230hp 325lb/ft
funflag is on a distinguished road
Default overheating/bubbling 5.9
I have a '93 dakota 5.9l 4x4 (I know it's not a ram, but I'm looking for some help, and the dakota site has offered nothing). I recently replaced the radiator, hoses, filler cap on the top hose, thermostat and cap. I am filled with 50/50 fresh coolant. I have pressure tested and no pressure loss. (I pumped up to 20lbs and it held for ten min.) I also tested the new cap, and that tested fine. If I get the engine hot, not from normal driving, reving the engine at idle, or driving in low gear, it bubbles over profusely into the overflow bottle after stopping. I had originally noticed this after towing a small pop up trailer. the needle doesn't have to get out of the normal range, just to the upper end. The aux fan works, fan clutch has no play no wobble/leak/noise from water pump. No white smoke, no oily radiator fluid. Heater works fine and top and bottom hoses both hot. Any help would be apprecitated. i am at a loss here...
Old 08-23-2010, 10:35 PM
You may want to test the cooling system for CO2 . Sounds like you may have a head gasket issue .
Old 08-23-2010, 10:46 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Did you try back flushing the system? Are you sure the thermostat is in correctly? I've seen them put in upside down before.
No milky oil? Have you pulled the plugs to see if they are damp? How does the motor run otherwise?
Brian:
Old 08-23-2010, 11:03 PM
Sounds like he has a cracked ring in the head gasket , allowing compression to get into the cooling system .
Old 08-23-2010, 11:13 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Welcome to the site. Looks like they have got a started in helping you solve your problem. Don't forget to head to the newbie checkin thread. We don't care about that you only have a Dakota, it's the Ram's little brother. Even our master tech here has a Dakota and not a Ram.
Old 08-24-2010, 01:06 AM
I left the pressure tester on and turned on the engine. About two min and no pressure buildup. Yes the thermostat is in correctly, I have double checked that. The engine runs fine. No milky oil. I have not checked the plugs yet. Thanks for the ideas so far. I will check for co2 tomorrow.
Old 10-02-2010, 12:25 AM
Many non-truck issues in life lately, I wanted to give an update and let everyone know what I determined was the prob. The radiator cap on my dakota is in the hose. I had to replace the filler cap fitting as the other one had cracked. The radiator cap was not fitting with enough pressure. I replaced it and problem solved. Luckily no big issue!!! Towed the trailer on a hot Az day into some 4 wheel drive terrain up some hills and no boil over. Thanks again for all the input.
Old 10-02-2010, 12:34 AM
moparmanicac's Avatar
moparmanicac moparmanicac is offline
Find em hot leave em wet
Vehicle: 12 RAM 1500 qc 4x4 HEMI
Trim Level: express
Color: bright silver
Rep:204
moparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura about
glad to see ya fixed if ya got a 5.9 dak im assuming the r/t or ya did a very nice engine swap?
[SIGPIC] RIP 02 4.7 Dakota sport qc 4x4
RIP 05 Ram 4.7 rc 4x4
HELLO 12 Ram HEMI qc 4x4 and 94XJ
