Confusing Heating Issue - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 08-24-2010, 10:02 AM
alfonso318's Avatar
alfonso318 alfonso318 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: 1500 (5.9L)gas
Rep:42
alfonso318 is on a distinguished road
Default Confusing Heating Issue
I have 01 Dodge Ram 4x4 5.9 L gas that had a thermostat fail...replaced it and it never seemed to reach a temperature that would heat up the cab (max temp on the gauge 170)...we flushed the radiator and put it back together and even replaced the thermostat...it appeared to heat the cab up a little bit more...according to a heat sensing gun it's plenty hot but the cab will not heat up...especially when it's cold outside...any thoughts on how to fix this?
Thanks
Old 08-24-2010, 11:33 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
When you flushed the radiator, did you back-flush the entire system including the heater core?
Brian:
Old 08-24-2010, 12:52 PM
alfonso318's Avatar
Rep:42
Yah we flushed it with water and compressed air...seemed to flow just fine and no real 'gunk' came out...so i'm super confused cause its gonna get cold here soon and the truck wont heat up or spit out hot air...i thought bout getting a cold weather grill guard....
Old 08-24-2010, 01:18 PM
Resident Technician
Rep:1915
Sometimes a heater core will just get so coated that a flush (even with compressed air) won't remedy the problem. If you're getting hot coolant in and out of both hoses, then you need a new core. I strongly recommend NOT using an aftermarket core. Make sure that your blend door is operating correctly too.
Old 08-24-2010, 01:27 PM
alfonso318's Avatar
Rep:42
Where should i located a heater core that is not an aftermarket one? Also how can i make sure the blend door is operating correctly?
What about the engine not heating up though? Do dodges typically run at a lower temp? Its no where near 210 in the middle...
Old 08-24-2010, 01:32 PM
Place your hand on the heater hoses once it gets up to temp . If their hot to the touch the problem isn't in the thermostat . It could be a clogged or dirty core .
Old 08-24-2010, 01:46 PM
Resident Technician
Rep:1915
If you have an infared temp gun, shoot the engine as close to the temp sensor as possible and that should give you a pretty accurate number. I would expect the temp to be within 10-20 degress of the thermostat spec. You can get an original equipment core from the dealership but it's going to cost a bit more. If your a/c is working like it should, you can change the temp settings from full cold to full hot and see a significant change. With the heater on full speed, floor setting, and the vehicle at operating temp, you should see a temp output of about 145F.
