Old 08-24-2010, 06:06 PM
ramman1967's Avatar
ramman1967 ramman1967 is offline
Vehicle: 01 ram 1500 quad cab 4x4
Trim Level: Laramie SLT
Color: Red/Silver
Rep:20
ramman1967 is on a distinguished road
Send a message via MSN to ramman1967 Send a message via Yahoo to ramman1967
Default Stuck doors
Would anyone know how to free up the rear passenger doors on a 1998 Ram 1500 quad cab?Any help would be great!!
Old 08-24-2010, 06:11 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Spray lube the hinges and latches would be my first choice.
Brian:
Old 08-24-2010, 10:29 PM
mlrtym's Avatar
mlrtym mlrtym is offline
Vehicle: 1994/98 Ram 2500
Trim Level: SLT Laramie
Color: Flat Black
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
mlrtym is on a distinguished road
if they are stuck closed, i had the same issue after the truck had sat for several weeks. i tried to spray from the inside while the door was closed, but even after sitting for a day, it still would not open. i had to use my feet from the inside. thought it was going to break something, but the door opened. then lots of lube, and do so every oil change since.
It is better to let one think you a fool, than to open your mouth and remove all doubt.
Old 08-24-2010, 10:54 PM
I'm starting to see this problem on my l/r door . I better do something about it before it's to late .
Old 09-05-2010, 11:44 PM
98Rammer's Avatar
98Rammer 98Rammer is offline
Vehicle: 1998 Dodge Ram 1500 4x4
Trim Level: Laramie SLT Club Cab
Color: Sonic Blue
98Rammer is on a distinguished road
Glad I found this thread, was just going to ask. My driver side rear half door is stuck shut, tried lube, and ZOOM, going to try a block of wood and a hammer tomorrow.
Old 09-06-2010, 09:07 PM
Dennyboy's Avatar
Dennyboy Dennyboy is offline
Vehicle: 1999 regular short box sport
Rep:140
Dennyboy will become famous soon enoughDennyboy will become famous soon enough
sounds like something is wedging shut. i would re shim them so that they are square.
Dakota County Technical college
Auto Tech apprentice
cataclysmic perverter
If you don't stand behind our troops, PLEASE feel free to stand in front of them.
Old 10-20-2010, 04:05 PM
ramman1967's Avatar
Color: Red/Silver
Rep:20
Got them open.I guess they were stuck from lack of use.I PB blasted the heck out of them.Let them sit for a few days and had my brother pull the handles while I gave them a few sharp boots with my foot.While I had them open I took the bottom latch off and took a wire brush to them and lubed them with grease.They work great now.Open very easy now.
Old 10-20-2010, 04:21 PM
Color: RootBeer
Rep:1287
Glad to hear it. If all else fails, get a bigger hammer.
Brian:
Old 10-23-2010, 12:59 PM
95ram 95ram is offline
Vehicle: 1998 dodge ram 1500
Color: red
95ram is on a distinguished road
I had this problem with my 98 1500. pb blaster is only a temporary fix. the only real way to fix the problem is replace the latch. hope this helps.
Old 10-25-2010, 01:05 PM
FloridaCracker352's Avatar
FloridaCracker352 FloridaCracker352 is offline
Vehicle: ram 1500 extcab 4x4 1998 dodge
Trim Level: larmine slt
FloridaCracker352 is on a distinguished road
Send a message via AIM to FloridaCracker352
i never had that problem on my 98 1500
