Old 08-24-2010, 09:18 PM
Skeeter43 Skeeter43 is offline
Vehicle: 2010 Ram crew cab
Trim Level: SLT--4x4 crew cab
Skeeter43 is on a distinguished road
Default traction control vs anti spin??
I need some clarification on this. I am looking to buy a 2010 hemi 4x4 crew cab. One has the 3.55 gears the other 3.92 gears. I understand the ratio but don't understand the difference between anti-spin and traction control any help would be appreiciated.
Old 08-24-2010, 10:36 PM
Anti spin may be the rear having a positraction unit in it .
Traction control is the electronic control of the system .
Old 08-27-2010, 01:46 PM
bamasport's Avatar
bamasport bamasport is offline
Vehicle: 2010 Dodge Ram 1500 Crew 4X4
Color: deep water blue pearl
Rep:186
bamasport has a spectacular aura aboutbamasport has a spectacular aura about
with the possi, you get two wheel peel instead of just one. the 3.92 gears are used more for towing or hauling as the 3.55 are the standard gears that all the 10 rams have, unless upgraded.
so if you plan on towing or hauling, i would recommend the 3.92, which is what i have in my truck.
like tom said, traction control is run by the computer and it senses when the rear wheel are spinning or not gripping the road. when it does the computer sends signals to one of the rear wheels and applies the break to regain traction. the 2010 also has a button in the cab that can be pressed to turn off the traction control. this is just a very quick explanation and in my words is what i have read. If i were you, i would read up on it, very easily googled like i did.
hope this helps ya out alil more
3.92 rear axle, OEM 20" rims, 20% tint, Mopar wheel-to-wheel side steps, K&N drop-in air filter, LineX bedliner, OEM Tow hooks, Rampage Tailgate Light Bar, Borla Cat Back, 6" BDS lift, 35x12.50x20 Nitto trail grapplers, Custom painted interior, dodge slush mats
JON
Old 08-27-2010, 01:48 PM
Rep:1885
Anti-spin is the posi unit in the rear diff. Traction control is electronic and works through the ABS and ETC.
