Old 08-24-2010, 10:41 PM
Meyster89's Avatar
Meyster89 Meyster89 is offline
Vehicle: 1998 Dodge Ram 5.9 4x4
Meyster89 is on a distinguished road
Exclamation Please help asap!!
Ok, so my 1998 5.9 is doing goofy stuff. This doesnt happen every day, but most. it will run fine for a few days then start acting up on my way home from work. It will run fine going down the road, but then sometimes at red lights it will want to die, punching the gas doesnt work,today it actually wanted to die while going down the road, as if the fuel/air mixture is bad? i have to turn the truck off, and restart which makes the truck run fine again. it wasnt throwing any kind of code until today, which was P0132, which is saying its running rich and pointing at the upstream o2 sensor, im planing on getting the sensor replaced tomoro, but what if thats not it?? im sick of putting money into it with no results.. please email me or post on here, sethmeyster@gmail.com . this is my only vehicle and i live 45 minutes from work, thus, i need a running vehicle..so please, any advice??? thanks tons!
recent fixes/"I thought that was the problem"... PCV, IAC, Plugs, Wires, been running 93oct fuel, ran seafoam through it.
Old 08-24-2010, 11:01 PM
DaddioDX DaddioDX is offline
Vehicle: 2005 Ram 1500
Trim Level: DAYTONA
Color: Go'ManGo
DaddioDX is on a distinguished road
My guess would have to be a leaky/sticking fuel injector. Seafoam is good, but Berryman's B12 Chemtool is best. Try some in a 1/2 tank or less. If it doesn't clear up check the plugs for 1 or 2 that are noticably cleaner (those would be the rich cylinders) and if a difference is found check those injectors. If none is found........ Try that O2 swap.... Or just replace the O2 sensor for the reason of age and mileage. I can usually find bad injectors with a stethoscope.
Old 08-24-2010, 11:21 PM
Meyster89's Avatar
any idea how much and how hard it is to replace fuel injectors? if i was to do that?
Old 08-24-2010, 11:23 PM
Rep:1845
Sounds to me like you could have paid to have it diagnosed with all the money you spent throwing parts at it. Crank sensors are known to cause problems like the one you describe without throwing any codes.
Old 08-24-2010, 11:31 PM
Meyster89's Avatar
I had a shop look at it, they said they couldnt find anything, and of course it idles fine when they have it at the shop. taking it to another shop in the morning.
Old 08-25-2010, 12:01 AM
Don't forget to stop by the newbie section and introduce yourself .
o2 sensor, red light die, rough idle
