CB Placement - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 08-25-2010, 02:39 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
Default CB Placement
OK, so evidently, CB is too common to search for. I want to put my CB in my truck, but can't seem to find a good spot for it. It is a smaller body radio (40 channel with squelch, volume, and PA), but it just doesn't look right anywhwere. I was wondering if any of you have put them in your Gen 4 trucks, and if so, how did you mount them.
I have the 60/40 bench in the front, with the step up from basic CD player. We are taking a trip to go hunting in two weeks, and it would be nice to communicate with the other trucks going.
Jeremy
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 08-25-2010, 03:08 PM
Rep:1625
I made a thread a while back with like 7 mounting locations for 3rd gen Rams, but I've only seen like three 4th gen Ram CB mounts. GTyankee has one in his truck. Here's his setup:
And here's one of the custom mounts I've seen:
Old 08-25-2010, 03:17 PM
Rep:1625
Here's the only other one I've seen:
I'm a huge fan of the dual antennas. I'd love a setp like this on my next truck:
Old 08-25-2010, 04:19 PM
Wildcat's Avatar
Rep:166
I definitely plan on running duals. As soon as I figure this out, and I will, I will post some pics. Nothing against any of those mounts, but I don't want it to be the center of attention. Dodge did a great job on the dash, so I would hate to mess it up. Hmmmmm.
Old 08-25-2010, 04:22 PM
Rep:1625
Yeah I hear you, it's tough to find the right spot. I might run the dual antennas just for looks for a while
Old 08-25-2010, 04:38 PM
Good luck on your placement . Let us know how it turns out for ya .
Old 08-25-2010, 04:41 PM
Will your unit accept a full control mic unit? If so, then you can mount the body of the CB under the center console or under a seat with only the hand unit mounted where you can reach it.
Old 08-25-2010, 08:02 PM
wallym777 wallym777 is offline
Vehicle: 2014 Dodge Ram
Trim Level: Lone Star
Color: Steel Gray
Rep:25
wallym777 is on a distinguished road
I am an amateur radio operator, mounted my main unit under the front seat and it has a full control remote unit that is on the dash. Basically, the front panel removes and is mounted remotely. I do not know if CBs do that. My antenna is mounted at the back of the bed, cabled through a small hole in the drain plug under the seat. The power is rounted thru the large firewall grommet behind the brake pedal. Truck is a center console 2010.
Old 08-25-2010, 08:51 PM
Rep:1625
Do you have any pics of your setup? I like the way it sounds
Old 08-25-2010, 09:33 PM
Wildcat's Avatar
Rep:166
I think I am going to mount it vertically in front of the center console. I will have to build a bracket, but that is no big deal. I do have a question, though. Will a spray in bedliner mess up the ground for the antennas?
