Old 08-25-2010, 04:27 PM
mineralram's Avatar
mineralram mineralram is offline
Vehicle: 2015 Dodge Ram
Rep:166
mineralram has a spectacular aura aboutmineralram has a spectacular aura about
Default so pissed off regarding tires and rims
I recently found a guy locally in my area who purchased a 2010 Quad Cab 1500 with the exact same tires and aluminum rims as mine on my 2009 Ram i offered him $ 800.00 buck cash for all 4 rims and tires he accepted. his rims and tires only have 50 kilometers on them he drove the truck from the dealer to the tire shop and bought new rims and tires the same day
But heres the kicker i called my dealer thinking i should be able to swap my tires and rims with his and keep my old set.
Dealer tells me i can not do that because the Tpm's in the 2009 and 2010 are different i called there bluff went to the guys house removed one of my tires and put one of his on they were right the light will not go out i said can you not reprogram them he laughed and said anything is possible for the right price but they would have to upgrade my computer and even then they will not guarantee it
Old 08-25-2010, 04:33 PM
Rep:1885
The light won't go out because each individual sensor ID has to be programmed into the WIN. As for the 09-10 being interchangable, I would think they are but can't say so with 100% certainty.
Old 08-25-2010, 04:36 PM
If you can find out the freq the 2009 tpms sensors broadcast at, you can get a set that work for the new wheels.
Or, re-use your old ones. Seems to me you are only gonna use one set of wheels and tires at a time.
Old 08-25-2010, 04:41 PM
sowardcustoms's Avatar
sowardcustoms sowardcustoms is offline
Vehicle: 2013 Ram R/T
Trim Level: R/T
Color: Gray
Rep:145
sowardcustoms will become famous soon enoughsowardcustoms will become famous soon enough
Yes you can... but the 2009 and 2010 are different and not interchangable just swap your old sensors in you new wheels....
Old 08-25-2010, 04:51 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
I've had the same issue with 2008 and 2010 sensors. Having to dish out $250 to get the four new sensors and have them put on.
Suck-dilly-ucks.
Old 08-25-2010, 04:53 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Give that man
Brian:
Old 08-25-2010, 04:58 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
You people and your fancy schmancy TPS's, glad I still roll the old way....
BTW, sorry to hear it, that sucks!
Old 08-27-2010, 11:20 PM
RamCountry's Avatar
RamCountry RamCountry is offline
Vehicle: 2006 Dodge Ram
Trim Level: Reg. Cab Laramie 4x4
Color: Atlantic Blue Pearlcoat
Rep:64
RamCountry will become famous soon enough
you should be able to swap over your old sensors to the new wheels i havent seen a sensor that you couldnt move to another wheel especially a factory one!
