Intergrated Trailer Brake Controll on the EVIC - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-25-2010, 10:41 PM
CanadianInfernoRed's Avatar
CanadianInfernoRed CanadianInfernoRed is offline
Vehicle: 2010 Ram 1500 Crew Cab 4x4
Color: Inferno Red
Rep:22
CanadianInfernoRed is on a distinguished road
Exclamation Intergrated Trailer Brake Controll on the EVIC
So I got my integrated trailer brake control installed today and when I got it home I noticed that the EVIC does not show any information on the display. How do I get the EVIC to display the trailer brake control and perhaps most importantly, does the integrated trailer still work properly if it does not show up on the EVIC?
2010 Dodge Ram 1500 SLT Crew Cab 4x4, 5.7L Hemi 390 hp 407 lb/ft
Old 08-26-2010, 12:03 AM
yagottaregatta's Avatar
yagottaregatta yagottaregatta is offline
Vehicle: 2012 Dodge Ram
Color: Deep Cherry Crystal
yagottaregatta is on a distinguished road
it should be in the vehicle info section of the evic scroll down to the bottom. Also if you push the slider on the control the evic will display the info for a few seconds. The brakes will still work if the evic does not show the info. If the evic never shows any info about the controller (ie when the slider is pushed or when you look in the vehicle info section) you need to go to the dealer and have them flash the code to your truck. Once flashed the evic will display the info.
BedRug, Bakflip Tonneau, Moroso Catch Can, Tint (all windows), Timbren helpers
Old 08-26-2010, 11:06 AM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
If you installed it, you will have to have the dealership add it to the sales codes, then you will need to have it flashed to update. If you do a search, there is a good thread on this. I think it was started by Cormac. Good luck.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 08-27-2010, 12:36 AM
Win's Avatar
Win Win is offline
Rep:99
Win will become famous soon enough
The dealer has to add the ITBM to your vehicle options first, then the vehicle needs to be reconfigured after the option is added. Where in Alberta are you?
Old 08-27-2010, 05:28 PM
Talayoe's Avatar
Talayoe Talayoe is offline
Color: Blue
Talayoe is on a distinguished road
I do believe its this write up to which you are talking about, started by Netman.
http://www.ramforumz.com/showthread.php?t=52410
Old 08-27-2010, 05:42 PM
DirtRider's Avatar
DirtRider DirtRider is offline
Color: Diamond Black
DirtRider is on a distinguished road
If you just added the controller to a truck that orignally came without it, you will also have the dealer flash the computer so it will recognize it.
I added the controller myself - very quick and easy process if you follow steps posted in this forum.
The controller worked right away, however it did not show in the EVIC.
With my oil change due, I also asked the tech to flash the computer to enable the integrated controller. They were extremely nice and did it for free.
Now it shows in EVIC under vehicle info - the icon if the trailer is attached and the breaking power aplied.
Very nice!
Old 08-27-2010, 06:44 PM
Color: Inferno Red
Rep:22
I am in the Lethbridge area.
Old 08-27-2010, 07:28 PM
Win's Avatar
Win Win is offline
Rep:99
Well I work up in Calgary. Easiest route for you is just pop in any dealership and tell them you've installed the ITBM and that you need to have it added to your options and reconfigured.
