Steering box play - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-26-2010, 10:23 AM
6speedhemi's Avatar
6speedhemi 6speedhemi is offline
Vehicle: 2006 Ram 2500
Trim Level: SLT Big Horn Edition
Color: Gray
6speedhemi is on a distinguished road
Default Steering box play
Hey guys. My steering box shaft has developed some side to side play, just enough so I can feel it in the steering wheel when I hit bumps. How much longer do you think I can go before replacing it? I know replacing it ASAP would be ideal but money is a little tight so I'd like to stretch it for a little longer. Thanks!
2006 Dodge Ram 2500, 5.7L Hemi, 6 speed manual, 4x4, 2" leveling kit w/ 35's, Aero Turbine 3030.
Old 08-26-2010, 10:47 AM
Resident Technician
Rep:1915
You might just need an over center adjustment as opposed to replacement.
Old 08-26-2010, 12:37 PM
DaddioDX DaddioDX is offline
Vehicle: 2005 Ram 1500
Trim Level: DAYTONA
Color: Go'ManGo
DaddioDX is on a distinguished road
Right on Randy. But I'm not sure if he means rotational slop in the steering shaft or side to side play in the stub shaft. Either way....... an over the center would show you the problem, and if it's just rotational slop that'll fix it.
Old 08-26-2010, 02:26 PM
6speedhemi's Avatar
Color: Gray
The steering isn't sloppy, I think the box is just getting worn out. If I grab the steering shaft right by the box and wiggle it I can feel side to side play. I can also feel the play if I grab the pitman arm and wiggle it. When I say "wiggle" I mean up and down, side to side, I'm not turning the shaft or pitman arm. Hopefully that makes sense, it's kinda hard to describe. Would a steering box stabilizer fix this? Or would that just be a temporary band aid? I appreciate the input!
Old 08-26-2010, 11:36 PM
nhegel's Avatar
nhegel nhegel is offline
Vehicle: 2007 Dodge Ram 1500 Mega Cab
Color: Electric Blue Pearl Coat
Rep:31
nhegel is on a distinguished road
I have same condition. I only feel it on bumps, and same play at box as you describe. Not sure what to do.
Old 09-02-2010, 09:48 AM
nhegel's Avatar
Rep:31
Bumping it up
