No Tach, no speedo and no charge - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 08-26-2010, 06:26 PM
walawdog walawdog is offline
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
walawdog is on a distinguished road
Default No Tach, no speedo and no charge
OK, so I have a 1997 2500 with the diesel and auto tranny. Just the other day the truck was running fine until I jumped into it at night to run to the store. Low and behold, there was no speedo, no tach and the alternator was not charging. Also, the tranny seemed like it was stuck in 2nd and will not shift up or down in drive. In addition, I cannot preheat my plugs, and the cruise control does not work. I replaced the battery and also the alternator with no luck curing anything. I am thinking that since all this happened in one shot...I think my trucks engine control unit is shot....what do you think?
Thanks for all the help.
Old 08-27-2010, 10:25 AM
johnny mac johnny mac is offline
Vehicle: 2000 dodge ram 2500
Trim Level: laramie slt
Color: red
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
johnny mac is on a distinguished road
Definatly sounds like a computer problem. Too many things wrong at one time. Have you had a shop run a diagnostic, they might get a code and tell you rightway. Good luck hope you get back on the road.
Old 08-27-2010, 10:30 AM
Resident Technician
Rep:1915
Geet it scanned for codes and diagnose it right instead of throwing parts at it. It will likely cost you less in the long run.
Old 08-27-2010, 05:17 PM
Default I did
I took it to the one local Dodge dealer and they said that the crank position sensor was out, the speed sensor on the tranny was out and, get this, the circuit board for the dash was bad....but I am thinking no way...all of those items going bad at exactly the same time. It sounds to me like they want me to throw parts at it until they figure it out...and I can't afford to do that.
Old 09-09-2010, 09:24 PM
JoeDodge JoeDodge is offline
Vehicle: 1998 quad cab 5.2 soon 2B 5.9
Color: blue
JoeDodge is on a distinguished road
I would check the crank sensor and the sensor wiring. It is located on the front of the engine and picks up a tach signal from the crankshaft pulley. It is held on w/ 2 nuts. The wiring connector is located just below the front of the valve cover meets the head. You can use a business card to set the gap on the new sensor. Has the drive belt broken recently? I have seen broken belts take out the sensor wiring. JoeDodge
Old 10-27-2012, 11:45 AM
ramtran ramtran is offline
Vehicle: 1995 dodge ram 2500 4wd auto
Color: blue
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
ramtran is on a distinguished road
Default trouble shooting
i have exactly the same problems. what did you do to fix all of these problems? thanks in advance ramtran.
Old 10-27-2012, 12:02 PM
Color: blue
waladog: i have the same symtoms with no tach speedo alternator could you please tell me what fixed it all ? thanks in advance ramtran
