View Poll Results: Which way is best?
Header-back duals (Completely separate) 1 100.00%
Headers to y-pipe (Single Exit) 0 0%
Header-Back duals (With H/X pipe ) 0 0%
Header to y-pipe (Dual exit single muffler) 0 0%
Other 0 0%
Voters: 1. You may not vote on this poll
Old 08-26-2010, 07:30 PM
Black05's Avatar
Black05 Black05 is offline
Vehicle: 2005 Ram
Trim Level: 1500 4x4 SLT
Rep:63
Black05 will become famous soon enough
Default Exhaust Options? Need Opinions
What is the best way to run my custom exhaust? Best for a balance of performance and sound
Recommendations on size- Is 2.5" big enough or should I be running 3"
Also what are some good headers? After some more research planning on longtubes.
05 1500 In Progress: Saving for more mods!
Old 08-26-2010, 07:37 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
I'm a fan of true duals, so I would recommend that. Have you done any research on the differences in all of them. I know with true duals you get some really good air flow.
Dillon-aka, The Little Kid
Old 08-26-2010, 07:42 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
I like the true duals myself, just make sure you have some kind of muffler to create back-pressure otherwise your forfeit low end power.
Brian:
Old 08-26-2010, 07:43 PM
Black05's Avatar
Vehicle: 2005 Ram
Rep:63
I've done some, I just haven't found any real good solid info on which flows the best. I was thinking at first true dual 2.5" all the way from the header back would plenty enough and better than stock. Then my mind just got to running and I started wondering if that would actually flow the best for my setup, and so I found some info (not sure on reliability) stating that by adding an H or X pipe in your duals can help with scavenging helping the exhaust to flow smoother and quicker resulting in better power. Also a single exhaust run at a larger diameter can flow as good or better if designed properly, basically take the stock setup and use bigger diameter tubing for more flow. I just don't know which will look-sound-perform the best...
RootBeer- Yeah I will be running mufflers as of now the resonated aeroturbine.
