Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 08-26-2010, 07:11 PM
Anthony C Anthony C is offline
Vehicle: 2005 DODGE 2500 5.9 CUMMINS
Color: LIGHT ALMOND
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Anthony C is on a distinguished road
Default Front engine seal
I have a question, my 05 CTD 5.9 drips oil from the front seal after shutting it down. Can the seal be replaced by removing the damper, or do I have to remove the front cover of the engine and take the seal out the back of the cover. Either way, I can do it I just wanted to know without looking and get a big surprise. I know some Chrysler engines seals had to be removed from the back of the front engine cover. I know it's a Cummins engine, but I don't know what Chrysler decided to do with the front cover on the Cummins. Thanking you in advance,
Anthony C
Old 08-26-2010, 08:59 PM
Resident Technician
Rep:1915
You need to remove the cover to replace the seal. It goes in from the front, but you need a specific seal driver to get it set at the correct spot. There is also a special tool that comes with the seal to guid it onto the crankshaft. Installing one is a delicate process and the seal is really easy to damage.
Old 08-26-2010, 10:20 PM
It's so nice having a Chrysler tech on board . Thanks Randy . Rep ya .
Old 09-03-2010, 07:49 PM
Diesel Geek's Avatar
Diesel Geek Diesel Geek is offline
Rep:23
Diesel Geek is on a distinguished road
you will need to drill a hole in the plasic guid tool as well there is a dowl pin in the crankshaft. if you do replace the seal your self dont drop the harmonic balancer . it is a a hydrolic damper and it will damage it badly.
Dodge forgot to tell every one the diesel is the SRT-6.
