Old 08-26-2010, 10:25 PM
sly96ram's Avatar
sly96ram sly96ram is offline
Vehicle: 1996
Trim Level: larmie slt 1500
Color: green and silver stripes
sly96ram is on a distinguished road
Default TransfeCase Hummmms
Well I am new to the truck and need little help. I noticed today a little bit of humming comming from the transfer case and notice some fluid leaking from it. I know i got to fill it up now but is it hard to replace the seals on the t case or something i can do in a day. And how do you know when its full.
Old 08-26-2010, 11:05 PM
Well hopefully it isn't damaged internally . The cases in the 1500's only hold a little over 1 quart of fluid . It doesn't take much to hurt them especially if it has been serviced like it should .
Old 08-26-2010, 11:17 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Don't know your t-case, but any I've worked on have a fill hole a few inches from the bottom, and you fill it to that level. If you have your owners manual, check to make sure you are using the correct oil for it. If you don't have the manual, check with your dealer to find out which lube is correct.
As for seals...is it only the front shaft seal that's leaking? Don't know on yours, but some you can replace that seal in about 30 minutes by only removing the front shaft and yoke...but like I said, I don't know on yours, and don't have a service manual for that generation of Ram.
Hopefully someone will be by shortly that is familiar with that t-case can tell you for sure.
Good luck with your repair, and hopefully there is no internal damage from low oil.
brad
Interested in one of my mods?
Old 08-26-2010, 11:27 PM
sly96ram's Avatar
Vehicle: 1996
It was a light hum just enough to know it was low it started today then i just parked the truck.
Old 09-01-2010, 06:41 PM
tuckertrucker's Avatar
tuckertrucker tuckertrucker is offline
Rep:34
tuckertrucker is on a distinguished road
Question T-Case Lube
Hi Guys
About the t-case lube. How do you change the lube to refill with new I have a 95 1500 slt 5.9 4x4 Getting a hum myself. Dont have a clue what kind of maint was ever done on this truck. I get this hum after reaching a certain speed and on coast BUT I feel it in the peddles and steering wheel. I have been told it could be the rearend. I would really like to narrow it down and not have to go through process of elimination.
1995 1500 4x4 360 3in lift 33 tires Magnaflow Gibson shorties Spectre CAI modded keg 52mm tb.
Old 09-01-2010, 06:44 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Go buy a Chiltons manual for your truck. It will walk you through all kinds of maintenance things as well as outright repairs and overhauls.
You can usually get them at the auto parts store or online.
Brian:
Old 10-18-2010, 12:43 PM
sly96ram's Avatar
Vehicle: 1996
Default out with the old in with the new!
So i decided since the humm was not getting any better i would just rebuild the transfer case. That was alot fun couple pics
out with the old in with the rebuilt
Old 10-18-2010, 08:01 PM
And did that take care of your hum ? Don't forget to service your transfer case as recommended . I would recommend to you to use a good quality synthetic tranny oil like Amsoil . I serviced mine late and it scared the hell out of me . It was suppose to be tranny oil in there . It came out looking like a dirty lightweight motor oil . Thank god no damage was done .
