Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 08-26-2010, 10:55 PM
rancherman's Avatar
rancherman rancherman is offline
Vehicle: My DD is '97 Dodge Ram 1500
Rep:171
rancherman has a spectacular aura aboutrancherman has a spectacular aura about
Default what next??!!??
My 6spd. on the '00 ram 3500 CTD took a crap today. I was pulling my pto generator trailer to the hay field, about 20 mph in 2nd gear. All of a sudden the whole shebang locked up. I immediatly pushed the clutch in and heard a bang. It was 'free' then. But even in neutral, something is 'in gear'.... and it's a higher one. Either direct or od. Pull it into gear, and its locked up again. probably 2 gears at once. Oh the humanity. man, I am almost out of wheels here~!
This one is going to the pro.
when I first got this about 4 years ago, it was hard shifting into 5 and 6th. Trans shop put in new syncros.... and it was much better.
My neighbor has a '97 2500 with ctd and a 5 spd. he has had the od gear fall off 3 or 4 times over the years. I think his last fix finally got it.
Does this sound like the same problem as the 5 spds?
This truck doesnt see the torture the '95 sees, mostly hiway miles. While almost always loaded, never 'overloaded' like the 95.
Old 08-26-2010, 10:59 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Wow, just curious did you check the shifter linkage to make sure it was not binding? I've had that happen in the past on manual transmissions.
Brian:
Old 08-26-2010, 11:19 PM
Man you just can't win can ya . Sorry to hear of the troubles your going through . Yes it sounds like it's stuck in two gears .
Old 08-27-2010, 08:53 AM
rancherman's Avatar
Rep:171
going to put on a straight jacket today. That way I can't drive/operate/bust anything.
Old 08-27-2010, 08:56 AM
iRESQu iRESQu is offline
Rep:2217
I am sorry that you are going through this! Try an extra cup of coffee! It always makes me feel better I hope you have a better day today!
Old 08-27-2010, 09:00 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Sorry to hear about the troubles, hopefully it gets resolved...
