after rotation, shake?? - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-27-2010, 02:50 PM
Banzai's Avatar
Banzai Banzai is offline
Vehicle: 2009 Ram 1500 4x4
Color: Inferno Red
Rep:64
Banzai will become famous soon enough
Send a message via MSN to Banzai Send a message via Yahoo to Banzai
Thanks GT, im gonna take my truck to either Kal-Tire here or one my buddies tuner shops.. they should be able to balance them correctly for cheaper..
just bugs me that i paid as much for this as i did and they are gonna nickel and dime me for stupid shit like this..
2009 Ram Sport 1500 4x4
22" Black Rhino Traverses | K&N | Carven Competitor | Dual Halo & Projector 6000k HID | Tinted Tails/3rd brake light | BT Catchcan | 6000k HID Fogs | Debadged | Tinted | RhinoLinings
Old 08-27-2010, 03:44 PM
Resident Technician
Rep:1915
Well, if they do find a bad tire or wheel problem, there's a slim to none chance that you will get reimbursed for what you spent but the dealer will warranty the defective part.
Old 08-28-2010, 12:13 AM
moparornocar72's Avatar
Rep:630
75 dollars is ridiculous. I could see if they were custom wheels and a pain in the *** to do but that is high. I work at a automotive shop. We do tires and wheels and more than likely when they mounted up the new wheels they balanced the new ones (maybe not) and let the other ones just rotate to the front because it was warranty work. 1/2 ounce to a full ounce and you will definately notice it, esp. if they have been riding good before hand. Also some other factors on balancing using the machines come into play. I worked for a shop that had the arm that spins with the wheel off balance throwing the tires and wheels off balance till they got it fixed we had a few people come back here and there. good luck.
14.268 @ 95 MPH Full Trim
Old 08-28-2010, 12:32 AM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
OK i will let you guys know now i work at a tire shop (Fountain Tire) I had a ram come in with the same problem...harsh shake after a rotate...pulled the wheels off immediately and checked balance and it was way out!! the reason it happens after a rotate is you cannot feel it as much in the rear...in the front you have the steering wheel to give feedback and you ride up front!
The causes can vary...weights slipping on these wheels is uncommon as far as i kno...marks where weights may look like they were are not "glue" the weights get hammered on a clamp around the rim lip...but the marks left are from older weights as road grime and dirt gets trapped under there! when they replace the tires it could have been as simple as someone to lazy to balance them...check for any weights on the wheels...i have also heard of tires physically spinning on the wheel, this will throw a tire way out as the weights that are on stay in the same spot and the tire moves, this is worse then not having any weights on the wheel!
So if re-balancing doesn't solve the problem, blown tire belt or bent wheel would be the next step to look for...being the truck is newer i wouldn't think bent wheels...worn front end parts can also cause a vibration, after a rotation is not likely!
Get them rebalanced ASAP...yes it not cheap to get balancing, my shop charges $15 per wheel for steel wheels, going up from there...but you have to think some of the machines cost up to $10,000 costs need to be covered some how!!
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 08-28-2010, 12:41 AM
rich1500's Avatar
rich1500 rich1500 is offline
Vehicle: 2013 Dodge Ram 1500
Color: Deep Red
Rep:12
rich1500 is on a distinguished road
Wow this all sounds like a big headache! Hope it doesn't happen to me when I rotate my tires. Good Luck Banzai!
Old 08-29-2010, 10:55 AM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
get a new balance and try a alignments you be fine
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 09-08-2010, 02:46 PM
Banzai's Avatar
Color: Inferno Red
Rep:64
went to canadian tire, got the tires balanced... 45.00! haha
one wheel needed 1.75oz and the other needed 2.00oz.. i was like wTF?
Old 09-08-2010, 02:50 PM
Resident Technician
Rep:1915
It's possible the last people that attempted to balance them had a machine that needed recalibrating. Regardless, I would ask for a refund since their balance didn't fix it and someone elses did.
Old 09-08-2010, 02:52 PM
Banzai's Avatar
Color: Inferno Red
Rep:64
i didnt pay the 75.00 at the dealership..
i said "$75?? ill go somewhere else, thanks..."
my friend works at a different dealership as an advisor, she said she would take of me from now on... local dealership is losing out now..
Old 09-08-2010, 02:57 PM
Resident Technician
Rep:1915
Ah ok. That price is too much for a balance, even for 20" wheels.
