Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Recalls and TSB's.
Old 09-02-2010, 04:35 PM
will's Avatar
will will is offline
Vehicle: 2010 dodge ram quad cab
Trim Level: slt/bighorn
Color: silver
Rep:43
will is on a distinguished road
The start-up clatter/ click is also effective on early model 10s. My dads truck just got them replaced today.(exhaust main bolts)
OLD TRUCK
NEW truck soon to be here
Old 09-14-2010, 11:18 PM
moparornocar72's Avatar
Rep:630
thanks will
14.268 @ 95 MPH Full Trim
Old 09-14-2010, 11:22 PM
Rep:630
Originally Posted by firelt View Post
Im interested in mor einfo on this one please and thank you!
A/T - Converter Shudder On Vehicles With Less Than 4K
HERE YA GO:
A/T - Converter Shudder On Vehicles With Less Than 4K Mi NUMBER: 21-022-08
GROUP: Transmission
DATE: October 8, 2009
SUBJECT:
Torque Convertor Shudder On Vehicles With Less Then 4000 Miles
OVERVIEW:
This bulletin involves using the StarSCAN(R) to verify that the "Torque Converter Break In" option is disabled (status = false).
MODELS:
2009 (DS) Ram Truck2009 (HB) Durango2009 (JK) Wrangler2009 (KA) Nitro2009 (KA) Nitro (International Markets)2009 (K1) Cherokee (CKD)2009 (KK) Liberty2009 (KK) Liberty (International Markets)2009 (LC) Challenger2009 (LE) 300C/300 Touring (International Markets)2009 (L2) 300 (China)2009 (LX) 300/Magnum/Charger2009 (ND) Dakota
NOTE :This Bulletin applies to DS/JK/LX/LE/LC/HB/KA/KK/K1 and ND models equipped with a 42 RLE transmission (Sales Code DGV) built before September 29, 2008 (0929XX MDH) or L2 models built with a 42 RLE transmission (Sales Code DGV) built before October 10, 2008 (1010XX MDH).
SYMPTOM/CONDITION:
Some customers may experience a shudder condition within the first 4000 miles. This shudder happens during steady state driving with the torque convertor in partial lock while the transmission is still in Torque Converter break in mode.
The shudder feels like the vehicle is being driven over rumble strips.
DIAGNOSIS:
Using a Scan Tool (StarSCAN(R)) with the appropriate Diagnostic Procedures available in TechCONNECT, verify all engine and transmission Systems are functioning as designed. If DTC's are present record them on the repair order and repair as necessary before proceeding further with this bulletin.
If the above symptom/condition is experienced or can be verified, perform the Repair Procedure.
SPECIAL TOOLS / EQUIPMENT REQUIRED:
REPAIR PROCEDURE:
1.Using the StarSCAN(R) select PCM.
2.Read DTC from the PCM.
3.Are any PCM DTC present?
a.No >>> proceed to Step # 4
b.Yes >>> Repair DTC as necessary then proceed to Step # 4
4.Select the "Misc Functions Menu" on the StarSCAN(R).
5.Select the "TCC Break In" option.
6.Select "Start" and the select "Next"
7.Select "View Current TCC Break-In Status"
8.Is the "Torque Converter Break In Complete status False?
a.Yes >>> Using the StarSCAN(R) disable "Torque Converter Break-In"
b.No >>> This bulletin does not apply, further diagnosis is required.
POLICY:
Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
More geared for 09 but 10 tsb havent been updated much recently
Old 09-15-2010, 11:22 AM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:83
Turbovsix will become famous soon enough
Awesome info - would you mind posting this one in detail? I have an appt scheduled for my dealer to review this issue. Front driver's seat squeaks like a 30 year old office chair!!
Interior - Front Seat Clicking/Squeaking/Creaking Noises
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI - all stock!
2012 Jeep Grand Cherokee Limited
Old 09-16-2010, 05:35 PM
Rep:630
Interior - Front Seat Clicking/Squeaking/Creaking Noises NUMBER: 23-011-09
GROUP: Body
DATE: April 17, 2009
SUBJECT:
Creaking, Clicking Or Squeak Sound From Seat
OVERVIEW:
This bulletin involves applying lube to the rear cross tube for front seats equipped with manual seat tracks.
MODELS:
2009 (DS) 1500 Ram Pickup
NOTE :This bulletin applies to vehicles with sales codes (JP8 or JRT) and built before March 13, 2009 (MDH 0313XX).
SYMPTOM/CONDITION:
The seats may make a squeak, clicking or creak sound when:
i.Stopping and accelerating
ii.Driving around corners
iii.Adjusting the seat
This may be more noticeable at colder ambient temperatures.
DIAGNOSIS:
If the customer describes this condition, perform the Repair Procedure.
PARTS REQUIRED:
NOTE : One can of lubricant can treat more than 10 vehicles.
REPAIR PROCEDURE:
1.Open passenger door.
2.Slide passenger seat to full forward position.
3.Disengage the 2 plastic J retainers underneath the rear of the seat from the support wire on the seat frame.(Fig. 1).
4.Disengage the plastic J retainer from the back-retainer is sewn into the cover and is a two piece plastic retainer (Fig. 2).
5.Protect floor and surrounding areas from excess lube.
6.Lift the lower section of the seat cover and move aside the foam covering the cross tube to metal bracket joint.
a.Spray lube (Sprayon S00202 11 oz. Moly Chain Lube and or equivalent) around the entire cross tube to bracket joint as shown in (Fig. 3).
b.Repeat for same joint on other side of seat.
7.Grasp the upper back of the seat being repaired and move side-to-side. If 'subject' noise is still present, repeat
8.Using a marker draw an X on the cross tube part label to acknowledge the seat has been lubricated (Fig. 4).
9.Reattach the two piece black J retainer.
10.Reattach the 2 white plastic J retainers.
11.Repeat Step # 1 through Step # 10 for the driver seat, if also equipped with manual seat.
POLICY:
TIME ALLOWANCE:
Rep:630
note if the pictures arent what they need to be alldata likes to change up there img codes so i appoligize
Old 09-19-2010, 08:55 PM
Ram1500SCC's Avatar
Ram1500SCC Ram1500SCC is offline
Vehicle: 2013 Ram
Color: Copperhead Pearl
Rep:30
Ram1500SCC is on a distinguished road
What about this one?
Wheels/Tires - Highway Speed Shake Or Vibration
Old 09-19-2010, 09:22 PM
firelt firelt is offline
Vehicle: 2010 Ram 1500
Trim Level: Bighorn SLT
Color: Dark gray
Rep:83
firelt will become famous soon enough
Thanks! just what I was looking for.
Old 10-08-2010, 05:23 AM
ALLPAR's Avatar
ALLPAR ALLPAR is offline
Vehicle: 2013 Ram 1500 Sport 4X4
Trim Level: Sport Crew Cab
Rep:100
ALLPAR will become famous soon enoughALLPAR will become famous soon enough
Please provide more information on the below TSB's. Thanks in advance for this great information.
Fuel System - Difficult Fuel Fill/Nozzle Shuts Off
2013 Ram 1500 4x4 CC Sport
Magnaflow exhaust, S&B CAI, Bully Dog Hemi+ tune, Bilstein 5100 set at 2.1, TLC air bag suspension, BT Catch Can, Vanish Low Profile tonneau cover, cabin air filter, AMSOIL fluids
***It's not Jet Noise, It's the Sound of Freedom!***
Old 10-08-2010, 03:39 PM
rainhater1 rainhater1 is offline
Vehicle: 2010 ram 1500 4x4 06 300 srt8
Trim Level: slt - big horn
Color: light graystone
Rep:116
rainhater1 will become famous soon enoughrainhater1 will become famous soon enough
Originally Posted by moparornocar72 View Post
If anyone wants more info on these bulletins let me know and I will post them but here is what they have so far:
All Technical Service Bulletins
Body - Hood Creaking/Squeaking Sound On Turns/Bumps
Entertainment System - Disabling Front Seat Video Source
Engine Controls - MIL ON/DTC
Recall 10V009000: Brake Booster Rod Clip
A/C - Hissing Noise With A/C ON
Engine Controls - TIPM Update For ECM PROM Update
Campaign - Windshield Washer Fluid Level Sensor
Maintenance - Fluid Flushing Information
Recall - HVAC Control Module Programming
Wheels/Tires - Chrome Clad Wheel Balancing Information
Engine Controls - MIL ON/Multiple DTC's Set
Parking Assist System - False Objects Indicated
Recall - Potential Clutch Pedal Link Separation (Canada)
Recall - Clutch Pedal Linkage Rod Defect
Engine Controls - MIL ON/DTC's
Body - Door Rubs On Fender When Opening/Closing
Recall 09V158000: A/C Control Module Programming
Wipers/Washers - Washer Solvent Level Sensor Weepage
Recall - Incorrect VECI Label Installed At Production
Recall 09V084000: Wiper Module Replacement
System - Radio Inop. After Battery Disconnect
Engine Controls - ECM Update For Spark Knock/Vibration
Engine Controls - Poor Idle Quality
A/T - Repair/Replacement Guidelines
Thanks for the thread, is there a way to put vin in and dump what it needs?
