Technical Service Bulletins 09-10 Rams - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Recalls and TSB's.
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 10-08-2010, 06:54 PM
Rep:2920
my dealership still has not received any where near enough of the Exhaust Manifold Stud Replacements, RRT 10-009 955 for the 5.7, (engine ticking sound in cold temperatures)
they just updated the PCM & TIPM software,
955 5.7L MIL is on found P0524 DTC (MDS oil pressure rationality) DTC is erroneous as set conditions are irrational
2 TSBs for this condition for driveability & MDS improvements.
TSB 08-018-09 for TIPM
TSB 18-019-09 PCM
one of these may have also had something to do with the Rams fuel saver light to finally start working
Old 10-13-2010, 01:06 PM
Jgroes Jgroes is offline
Jgroes is on a distinguished road
Default Info
moparornocar72,
Appreciate the help and info. When you have a few, can you post details on the following TSB's:
-Engine Controls - ECM Update For Spark Knock/Vibration
-Engine Controls - Poor Idle Quality
Many thanks!
Regards,
JG
Old 10-13-2010, 10:59 PM
moparornocar72's Avatar
Rep:630
Sorry I am just now getting in from work and school:
Engine Controls ECM Update For Spark Knock/Vibration
NUMBER: 18-041-08
GROUP: Vehicle Performance
DATE: December 16, 2008
THE StarSCAN(R) FLASH FILES FOR THIS BULLETIN MUST BE RETRIEVED FROM THE INTERNET.
StarSCAN(R) SOFTWARE LEVEL MUST BE AT RELEASE 9.03 OR HIGHER FOR THIS BULLETIN.
StarMOBILE STANDALONE MODE OR StarMOBILE DESKTOP CLIENT MAY ALSO BE USED TO PERFORM THIS PROCEDURE.
SUBJECT:
FLASH: Spark Knock Improvements And Noise Vibration Harshness (NVH) Improvements
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Powertrain Control Module (PCM).
MODELS:
2009 DS Ram Truck 15002009 (WK) Grand Cherokee2009 (WH) Grand Cherokee (International Markets)2009 (XK) Commander2009 (XH) Commander (International Markets)
NOTE :This bulletin applies to vehicles built with a 5.7L engine (sales code EZD) on WK/WH/XK/XH built before October 28, 2008 (1028XX MDH) or DS vehicles built before October 3, 2008 (1003XX MDH).
SYMPTOM/CONDITION:
Some customers may experience:
^NVH issues while the vehicle is operating in the MDS mode.
^Spark Knock between 1800 to 2500 RPM.
DIAGNOSIS:
Using a Scan Tool (StarSCAN(R)) with the appropriate Diagnostic Procedures available in TechCONNECT, verify all engine systems are functioning as designed. If DTC's are present other then the one listed above record them on the repair order and repair as necessary before proceeding further with this bulletin.
If no DTC's are present, perform the Repair Procedure.
PARTS REQUIRED:
SPECIAL TOOLS / EQUIPMENT REQUIRED:
REPAIR PROCEDURE:
1.Reprogram the PCM with the latest software. Follow the detailed service procedures available in DealerCONNECT/TECHCONNECT, Refer To 8 - Electrical/Electronic Control Modules/Powertrain Control Module - Standard Procedure PCM/ECM Programming - Gas.
2.Type the necessary information on the "Authorized Modification Label" p/n 04275086AB and attach it near the VECI label.
POLICY:
Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
FAILURE CODE:
Disclaimer :This bulletin is supplied as technical information only and is not an authorization for repair.
Engine Controls Poor Idle Quality
NUMBER: 18-038-08
DATE: October22, 2008
SUBJECT:
Flash: Idle Quality Improvements
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Powertrain Control Module (PCM) with new software.
MODELS:
2009 (DS) Ram 1500 Truck
NOTE : This bulletin applies to two wheel drive (4x2) models equipped with a 5.7L engine (sales code EZD) built before October 3, 2008 (MDH 1003XX).
SYMPTOM/CONDITION:
Some customers may complain of the idle quaility after the vehicle is warmed up. This condition can happen while the vehicle is in park, neutral, drive or reverse with no additional throttle tip in. A software change has been made to the increase the warm nominal idle speed from 584 rpm to 648 rpm, which corrects the condition.
If the vehicle owner complains of this issue reprogram the PCM with the new software.
DIAGNOSIS:
Using a Scan Tool (StarSCAN(R)) with the appropriate Diagnostic Procedures available in TechCONNECT, verify all engine systems are functioning as designed. If DTC's are present record them on the repair order and repair as necessary before proceeding further with this bulletin.
PARTS REQUIRED:
REPAIR PROCEDURE - USING THE INTERNET TO RETRIEVE THE FLASH FILE:
1.Reprogram the PCM with the latest software. Follow the detailed service procedures available in DeaIerCONNECT/TECHCONNECT, Refer To 8 - Electrical/Electronic Control Modules/Powertrain Control Module - Standard Procedure PCM/ECM Programming - Gas.
POLICY:
TIME ALLOWANCE:
FAILURE CODE:
HOPE THIS IS WHAT YOU WANTED, LET ME KNOW IF THERE IS ANYTHING ELSE I CAN DO!
14.268 @ 95 MPH Full Trim
Old 10-13-2010, 11:02 PM
Rep:630
2010 Ram TSB's So Far 10/13/10 10:03 PM
Number Date Title
22-001-100 4/08/2010 Wheels/Tires - Highway Speed Shake Or Vibration
08-004-100 3/02/2010 Entertainment System - Disabling Front Seat Video Source
J370 1/25/2010 Recall - Brake Pedal Linkage Clip Missing/Defective
NHTSA10V0090000 1/07/2010 Recall 10V009000: Brake Booster Rod Clip
Old 10-13-2010, 11:07 PM
Rep:630
Again if anyone wants further info, post it or pm me.
Old 10-14-2010, 09:22 AM
Default Thanks
Appreciate the quick reply.
Best regards,
JG
Old 10-14-2010, 05:55 PM
Rep:630
anytime and if the pictures above shift let me know. alldata is bad about shifting there imaging
Old 11-16-2010, 12:29 PM
GWTaylor GWTaylor is offline
GWTaylor is on a distinguished road
I have been having issues with the drivers seat in my 2010 ram st. Do you have more info on the tsb listed in your post for
"Interior - Front Seat Clicking/Squeaking/Creaking Noises"?
Old 11-19-2010, 01:34 AM
Rep:630
look in the pages before on this thread and it's posted. hope thats what you were looking for, sorry i just now realized i had a new post.
Old 11-20-2010, 01:00 AM
battlerattle's Avatar
Vehicle: 2016 Ram 2500 Laramie LongHorn
Trim Level: Laramie LongHorn
Color: Granite
Rep:286
Just so you are all aware. When I had my 2010 1500 in for service last month they replaced the seal on the CHMSL (Center High Mounted Saftey Light) aka: the third brake light on the back of the cab. There is a service bulletin out that the seals dry out and crack.
Just thought I would share.
Just Got it, Give me time!
