transmission upgrades ? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 08-28-2010, 10:39 AM
CPRAM CPRAM is offline
Vehicle: 07 Ram Quad cab 2wd
Color: Inferno Red
CPRAM is on a distinguished road
Default transmission upgrades ?
Are there any types of upgrades that can be done to help while towing a trailer
Old 08-28-2010, 11:00 AM
iRESQu iRESQu is offline
Rep:2217
Hello and welcome aboard the ForumZ. Great to have you. I am not sure about upgrades for a transmission, so I will let the pros handle this one. I do know that when I had a tuner on my truck, the gears shifted so much more smoothly and rapidly, but I WASN'T TOWING. Hang tight and someone with vast more knowledge on this subject will chime in. Thanks and see you around!
Old 08-28-2010, 11:32 AM
Rep:4264
I see you already had a newbie thread, so I moved your post over here where we can hopefully get you the answers you need.
Old 08-28-2010, 03:35 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
What kind of towing issues are you having? What kind of gearing does your Ram have?
Shouldn't be any issues with the transmission. Are you using the tow/haul mode (ie light on)?
Brian:
Old 08-28-2010, 04:30 PM
You bet there is...add a transmission oil cooler. If you already have one, you should be good unless you are planning on towing beyond the rated capacity for the truck.
Old 08-29-2010, 10:21 AM
Color: Inferno Red
I already have the tow package on the truck ,i think that cooler is there ,it just doesnt seem to want to shift into 4th gear fast enough the thing is screaming at about 4000 rpm then finally shifts. This is only when towing though other wise it all seems fine.Would a tuner really help this?
