New to forum and owning a dodge. Need help! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 08-28-2010, 10:41 AM
rexhalbert rexhalbert is offline
rexhalbert is on a distinguished road
Default New to forum and owning a dodge. Need help!
Had to pull someone out of a ditch and had to put it into 4lo. After pull the e-brake light, abs light, and 4wd light were stuck on. e-brake and abs eventually turned off but truck is stuck in 4lo. When you put it neutral and turn the knob to 4hi or awd it will light up for a moment but just go back to lighting up 4 lo even when the knobs not there. Please how do I get it unstuck?
Old 08-28-2010, 10:53 AM
iRESQu iRESQu is offline
Rep:2217
Welcome aboard the ForumZ. Great to have you.
So your truck isn't stuck in 4lo, correct? Just the light? I don't want to lead you wrong, so here is my .02 until A PRO chimes in. If it was me, this is my attempt:
1) Check relays, fuses, connections for loose wires/grounds.
2) Disconnect your battery, let it set for a few minutes and then reconnect. See if it pops back on.
I AM NOT A PROFESSIONAL. Hang tight and a more experienced member will chime in. Best of luck and keep us updated.
One other thing, make sure you have updated your User CP so we have all the necessary details of your truck to get you a more rapid response. Thanks!
Old 08-28-2010, 11:06 AM
Default Truck stuck in 4lo after towing someone out of ditch
My Dodge ram 1500 hemi won't come out of 4lo. I'm new to owning a Dodge and 4WD. Need suggesstions please
Old 08-28-2010, 11:38 AM
Engine: 2002-2012 226ci (3.7L) Magnum/PowerTech V6 215hp 235lb/ft
Rep:4376
I don't really have an answer for you, but hang in there, someone who can help should be along shortly and welcome to the forum!
Old 08-28-2010, 12:44 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Welcome to the site!
Old 08-28-2010, 12:48 PM
Rep:1625
Welcome to the forum! Sorry I'm no help on this one, but what year is your truck? The more details we have, the more accurate the response
Old 08-28-2010, 03:10 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Welcome to the Z. iCoveru gave you some good suggestions. One I would add is to put it in reverse for a few feet, stop, put it in neutral then try getting it into 2hi.
We have a lot of forums for all kinds of topics, so you shouldn't have any problems finding a place to post questions.
We LOVE pics of Rams.
Here's how to post them: http://www.ramforumz.com/forumdisplay.php?f=73
Brian:
Old 08-28-2010, 04:16 PM
Try a short distance in reverse to unlock the hubs.
Old 02-01-2014, 05:32 PM
bubblehead's Avatar
bubblehead bubblehead is offline
Vehicle: 2006 Dodge Ram 1500
Rep:13
bubblehead is on a distinguished road
When you pulled the other guy out, did you jerk him out, or was it a smooth pull? If you had to jerk him a lot, or hard the transfer case may have locked up or bound up. This happen to my buddy. Like everyone else has said, im no where near a pro. welcome btw.
2006 Ram 1500 Laramie 4x4 5.7 Hemi
"The Black Bandit"
