Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - News Desk > Newbie Checkin!
Newbie Checkin! New to the forums? Introduce yourself here!
Old 08-28-2010, 02:16 PM
welshdog welshdog is offline
Vehicle: 2005 Dodge Ram 1500
welshdog is on a distinguished road
Smile TPS and transmission noises
Hi there,
would be grateful for advice on this topic. Vehicle is a Dodge Ram 1500 4.7 V8 magnum (2005 model). Idle speed was really erratic, 600-1800rpm and cutting out at times. Whilst driving there was an audible "clunk" from the transmission on downchange whilst braking. Very worrying! Changed the TPS and the idle speed is now constant at 600rpm. Also checked for vacuum leaks but all seemed Ok in that respect. The transmission problem also (hopefully) seems to be resolved....I hope this is the case,and the problems were related. Does anyone know if these problems are related,and the transmissions downchanges were noisy due to the engine speed being out of sync.? I am hoping this is the case and the transmission is OK,just the TPS was causing a glitch. Thanks for any info. about this.
Rob Tate
Old 08-28-2010, 03:38 PM
iRESQu iRESQu is offline
Rep:2217
Hello and welcome aboard the ForumZ. Great to have you! Because I am not experienced anywhere near enough to properly advise you, my next suggestion is to get your issue posted in a section that our techs and experienced members can get to you hopefully a little quicker:
http://www.ramforumz.com/forumdisplay.php?f=205
Until then, post some pics of your truck, chat with other members and hang tight for an answer! Talk to you soon.
Old 08-28-2010, 04:22 PM
Hey! Thanks for the advice,have done this and await answers.
Sincerely Rob Tate
Old 08-28-2010, 04:33 PM
Welcome to the forum.
I don't believe the idle issue and the transmission clunk are related. You will get some clunk when shifting from Park and Reverse to D. But I would get under the truck and, while it is Park, at the rear differential end rotate the driveshaft and observe the u-joints. Try to measure the amount of movement.
Also do the same thing at the transmission yoke/u-joint.
Old 08-28-2010, 04:47 PM
Rep:4072
Hello and welcome to the forum, glad to have you! I'm not much help on this one, either, but looks like Michael has some good advice, so hopefully the knowledgeable folks on here can help you get it figured out! In the meantime, lots of great people and info here, so feel free to look around and join the conversation and I hope you enjoy the site!
Old 08-28-2010, 04:49 PM
Hi Michael,
thanks for the tip! Did this and there is no discernible movement on the propshaft at either end, so I guess the yolks are OK. However it was worth checking that option out.
Sincerely Rob Tate
Old 08-28-2010, 04:59 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
I don't know diesels. However, given the age of the truck, when was the last time the tranny filter was changed the ALL the fluid flushed?
Brian:
Old 08-28-2010, 05:16 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
Hello and welcome!
We are glad to have you with us, I hope you enjoy it here!I see you have gotten some help, I hope it works!
Old 08-28-2010, 05:17 PM
Hi Rootbeer,
I dont know.....I haven't done it and cant find when to do this in the handbook under maintenance. Sounds like this should be done now.I know I have no leaks on the tranny fluid. Thanks for your advice,will do this ASAP!
Sincerely Rob Tate
Old 08-28-2010, 05:19 PM
Color: RootBeer
Rep:1287
Originally Posted by welshdog View Post
Hi Rootbeer,
Sincerely Rob Tate
Forget my comment on the diesel, looked at the wrong post.
So, this brings up another question, have you cleaned the throttle body? Can of brake cleaner, toothbrush and a little elbow grease.
As for the tranny fluid, what color is it? What does it smell like?
Brian:
